1988 lx
9.68@142
setting adjustible upper control arms?
so i just bought a set of adjustible upper control arms i know how to install them but how do i go about setting the correct pinion angle?
1988 lx
9.68@142
i also bought a set of lakewood lower control arms.
1989 Mustang LX
10.98@126.7 NA
I have the Lakewood lowers with UPR adjustable uppers with the the solid spherical axel bushings. I also have the Comp Engineering anti roll bar. I started with adjusting the uppers to stock length and then adjusted to -4 degrees pinion angle with the car weight on the wheels. Total angle depends on the total deflection of the suspension at launch so fine tuning may or may not be necessary. My sig pic is of the car launching with that set up.
Never fast enough.
1988 lx
9.68@142
ya my car squats like a mofo what do you use to deturmine -4*
#5 | |
*With rubber bushings: Set Pinion Angle -3 degrees to -4 degrees* *With polyurethane bushings: Set Pinion Angle -2 1/2 degrees to -3 degrees* *With solid bushings: Set Pinion Angle -1 degrees to -1 ½ degrees* Now you can adjust the passenger side control arm so the mounting bolt will slide in and out with no tension on it. Now your pinion angle is adjusted and you have zero preload on the rear suspension. If you don’t have a rear anti roll device then you can add preload in one direction or the other to help correct any issues with the car steering left or right on the rear tires. Zero preload is a good starting point. If you have an anti roll device then just keep the preload at zero and adjust the anti roll device to make the car track straight.
#6 | |
1988 lx
9.68@142
1988 lx
9.68@142
and thanks for taking the time to write that up for me
No, an anti roll device. Much different than a factory type sway bar.
1988 lx
9.68@142
ok then nope no anti roll device.
Threads Similar to: setting adjustible upper control arms?
| Upper and lower control arms | gt_andy | 99-04 | 30 | June 19th, 2008 10:26 PM |
| Upper Control Arms & Lower Control Arms | LUV2XLR8 | 2005 - 2010 | 6 | October 6th, 2007 11:45 AM |
| Upper and Lower Control arms! | MustangMatt96GT | 96-98 | 10 | June 28th, 2007 02:40 PM |
