cam help
LinkBack (1) Thread Tools
Old October 19th, 2008, 09:04 PM   1 links from elsewhere to this Post. Click to view. #1
1990 Mustang GT
13.64 @ 101 MPH
GoodOleBoyzRacin is on a distinguished road
cam help
searched for topic but nothin came up. i had a copy of the timing marks on the crank and cam sprockets but im afraid it wasnt right. dot on cam sprocket at 6 and key on crank at 12? now when i try to spin my engine over by hand it wont turn.........i havent put the timing cover back on yet in case i need to adjust something. if the #1 cylinder is at TDC will the timing mark on the crank be where i need it to be? then i can line it up with the cam? there is no coil bind or PTV. it is a TFS stage 1 cam. on my last stang i installed a E cam and it did the same thing so i got somebody to do it for me. what did i do wrong?
90 Ford Mustang 5.0 T5- BROKE
1.9 60' on street tires13.64 @ 101 MPH
89 Ford Mustang coupe- http://www.youtube.com/watch?v=1nIrzcQz3_8
Old October 19th, 2008, 09:49 PM   #2
1990 Mustang GT
13.64 @ 101 MPH
anybody?
Old October 19th, 2008, 10:01 PM   #3
1986 mustang gt
tvc2389 is an unknown quantity at this point
Send a message via AIM to tvc2389
what kind of heads r u using
Old October 20th, 2008, 01:26 AM   #4
1990 Mustang GT
13.64 @ 101 MPH
stock heads, 90 model HO motor, stock rockers, stock length pushrods, stock springs, etc. im savin up for some used edelbrock performers that have been CNC ported, roller rockers, .650 lift springs, etc. i just need to know if i put the motor on TDC on comp stroke will everything line up like its suppose to? and why would it be hard to turn by hand, like i can damn near stand on the breaker bar and wont turn, if there is no coil bind or PTV issues.
Old October 20th, 2008, 01:34 AM   #5
flattusmaximus78's Avatar
1993 5.ohhhh
12.97 @140mph
my motor was the same way on the stand. I had a big torque wrench and some serious muscle to crank it by hand. I started it up first time the other night. High oil pressure all seems good so far.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed
--Moates Quarter horse $225--
--Cobra intake $150--
--tremec 3550 bell and shifter $1100--
Old October 20th, 2008, 01:35 AM   #6
1990 Mustang GT
13.64 @ 101 MPH
darrell? got any .02?
Old October 20th, 2008, 04:43 AM   #7
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Sounds like you installed everything correctly. Are the spark plugs in? If so take them out and try to turn it over. Keep in mind that you know have valve spring pressure that you are working against now too so you are probably going to need something a bit longer than a ratchet to give you some leverage.
Old October 20th, 2008, 12:10 PM   #8
1990 Mustang GT
13.64 @ 101 MPH
thats what somebody else told me. ill pull the plugs today and see. long day today. picked up a 89 coupe, gotta drop in motor and tranny, wire up the msd, swap in the gas tank, hook up the fuel pump, hook up the nitrous, and hopefully get yall a startup vid..
Old October 20th, 2008, 07:44 PM   #9
1990 Mustang GT
13.64 @ 101 MPH
ok turns freely now. it was installed at TDC on exhaust stroke instead of compression. thanks fellers
Old October 20th, 2008, 09:33 PM   #10
PeteAndersonRacing.com
Old October 20th, 2008, 10:34 PM   #11
So you lined up dot to dot with the cam sprocket dot at the top?
Old October 21st, 2008, 02:55 AM   #12
1990 Mustang GT
13.64 @ 101 MPH
i think. somethin was up. cause i re-aligned everything with the rockers loose, then bolted it all back up and it turns easy now. even with the spark plugs out i couldnt turn it but now it does so im not gonna worry about it. start up vid tomorrow
Old October 21st, 2008, 03:26 AM   #13
e3sean's Avatar
1988 lx
9.68@142
good luck
<font size=4><b>MILITARY CREW
Old October 21st, 2008, 06:25 PM   #14
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
That is impossible if the cam dot was at 6 o'clock and the crank was at 12 o'clock. Like 93mustank said, the cam would be at 12 o'clock as would be the crank.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/93796-cam-help.html
cam help This thread Refback October 20th, 2008 04:59 AM
Threads Similar to: cam help
what cam should i use?! 5.065stang 5.0 Mustangs 0 July 13th, 2008 03:31 AM
289 cam vs 351 cam Kenn Classic Mustangs 11 May 5th, 2008 01:20 PM
N/A Cam and Blower Cam ??? StuTheMusicEngineer 99-04 1 March 3rd, 2007 04:35 AM
E cam or F cam horsepower and 1/4 mile time questions GreyGhost 5.0 Mustangs 1 August 21st, 2006 06:25 PM
