1986 LX
none yet
oil in coolant but no coolant in oil?
Okay weird stuff yesterday after flushing my 91s cooling system. I just did the heater core replacement which was a living hell I might say. But when I drained all the coolant there was that neat rainbow look to it in the drain pan and of course it was oil. I dont know how. I made sure to check the oil and figured it to be all milky but it is fine. Right away my guess is head gasket. I guess it could be a cracked/warped head too though right? or who knows what? Any ideas? I already have another block im putting together for this one so Im not too stressed about it but it would be nice to know what everyone thinks.
not to ask stupid questions but was the drain pan clean? could it have had some oil residue in it?
[SIGPIC][/SIGPIC] [SIZE="4"]"This just in....14.79 @ 92.15 is not fast"[/SIZE] |
was the bottom of your overflow tank peanut buttery looking? cause mine was
95 Mustang GT
I was gonna ask this same question. I have reused a drainpan before and thought this same thing. It doesnt take much to leave the rainbow effect.
![]() People should think about boarding up their glass house before starting a rock fight! |
same here. i guess the only stupid question is the one that isn't asked
#6 | |
95 opalfrost gt
Intake gasket leak.
Skirt Chasing Phallus Phondler
Kit Car/Ducati/Explorer
Nike Fast
I agree it does sound like an intake gasket...
QUOTE OF THE DAY (5/25/12): “Don’t play what’s there, play what’s not there.” ‐ Miles Davis |
1986 LX
none yet
1988 lx
9.68@142
uausally its water in the oil cause the water is under more pressure.
when i blew an intake gasket my oil turned into a milkshake
1988 lx
9.68@142
exactly. i have never seen oil in the water unless the pressure side after the pump cracked into the water
1986 LX
none yet
I have blown head and intake gaskets both resulting in a creamy milkshake like oil. I understand thats typical. Thats why I said this is really odd. How would I get oil in the water but not water in the oil. it doesn't make sense to me
Oil pressure is much higher then coolant
your coolant pressure is as high as your radiator cap states. which is about 16lbs vs oil that its usually never that low. and about 35-80+psi an intake gasket leak would only lead to water in the oil which would be milky when first coming out if you let it sit. the water will be at the bottom but still mixed. plus no oil runs through your intake so its impossible for oil to get in your coolant through a leak there most likely a head gasket. thats the only thing that i can imagine would cause oil in your coolant. which when you turn your car off your coolant pressure stays present while you have 0 oil pressure so water can still get in your oil that way
Maybe the oil was already in the coolant when added. Typically if I drain the coolant and it doesn't need to be changed, I will recycle it. If there was any oil residue in the drain pan it goes in the coolant too. Another possibility, is ATF if you have an automatic. Coolant hoses that route through the radiator for cooling have been known to corrode.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
1986 LX
none yet
Ahh maybe that has something to do with it. About 6 months ago I did the swap from aod to the t5. But I haven't flushed the cooling system since then so there could still be residual from the trans before. I guess Ill just have to keep an eye on it
Threads Similar to: oil in coolant but no coolant in oil?
| 99 Cobra 4.6 Oil Cooler machined hole porting Oil? | ocJB3 | 99-04 | 3 | January 3rd, 2011 06:31 PM |
| kickout 7qt oil pan w/low oil sensor hole | Iownastang | 5.0 Mustangs | 2 | July 19th, 2007 01:17 AM |
| location of oil pressure switch and/or coolant sensor on a h | sweet99 | 99-04 | 2 | March 23rd, 2007 07:12 PM |
| oil in my coolant | kdawg48_2000 | V6 Mustangs | 2 | August 6th, 2006 11:18 PM |
| oil in my coolant | kdawg48_2000 | General Tech | 2 | August 5th, 2006 09:08 PM |
