1990 HATCH
12.56@118
Running HOT!
Car starts to run Really hot (almost over heating) when driving for about 20 min. I have aluminum heads and afraid of them getting warped. Should i try a 160 thermostat? Anything will help. Thanx
First you should make sure your existing thermostat is even opening when it should be. I think the computer works best with the 180. Maybe your radiator is clogged. Stock mustang rads are not known for their cooling when the car had mods on it. Also make sure you have the proper mix ratio of 50/50 in the rad. If your car is almost overheating I highly doubt a lower temp thermostat is gonna help. Might have water pump problems also.
#3 | |
1993 Mustang LX Vert
I would definitely check the radiator, i had the same problem and thought it was a faulty signal because the radiator was full and the overflow was at the right level, then a couple days later it ran hot and blew the head gasket.
Threads Similar to: Running HOT!
| Got Her Running, But wont stay running...help? | Speedstang302 | 5.0 Mustangs | 10 | August 28th, 2011 06:58 PM |
| RUNNING HOT!!!!!!! | BLACKNIGHT5.0 | 94-95 | 37 | September 5th, 2007 04:27 PM |
| not running right | jkovacs60 | General Tech | 2 | August 3rd, 2007 03:13 AM |
| Bad running... | alabamastanger | 5.0 Mustangs | 4 | July 15th, 2007 07:25 PM |
| Just Got Done Running a 89 LX 5.0 | Bigb2000GT | 99-04 | 1 | March 19th, 2007 07:57 PM |
