1986 mustang GT T-top
What next ?
ok i have had my car for some time now and i was wondering what should get next for my car.
I HAVE Cat-back 2.5 to 3 tips from pypes FIPK cold air intake 3.73 gears (coming this xmas) so what should i get now to get a little bit more power LAter |
cylinder heads
[SIGPIC][/SIGPIC] [SIZE="4"]"This just in....14.79 @ 92.15 is not fast"[/SIZE] |
Priest of the Car Gods
Suspension or Tires.
Do more with the power you already have.
MSTRB8N & MDR8N
2021 Mustang V15
Quad Turbo with nawz
i gained a noticeable amount of power from my BBK o/r H-pipe, and it sounds mean as hell now too
MM 1 am boner crew Cars and mod list in garage i like veiny meat sliding between my buttcheeks |
1988 lx
9.68@142
electric fan,manual rack, heads cam and intake
good lower control arms and subframe connectors is a great start. to answer your origional question about making more power, there's nothing better than a set of heads. everything you do is limited by the flow of your heads
yeah look around for a good set of heads also check into lower control arms
well i dont want to get lower arms because i want to keep the height stock because im getting SC rims and the back rims are 17 x 10 and i dont want to worrry bout the clearnce
oh i was think bout saving up and buying this kit right here
Trick Flow® 360 HP Twisted Wedge® Top-End Engine Kits for Ford 5.0L: TFS-K514-360-350 - trickflow.com |
#13 | |
87 Mustang GT T-top
If you are a T-top like i am i would also recommend subframe connectors like Stangfreak said. They helped me alot with flex on the car, since we have T-tops it has a little bit more flex in it than most Mustangs our style. I noticed the difference. Also you can get them pritty cheap too. I found some Weld ons for like $60 bucks or so. I woud go Weld on, IMO. Heads can get expensive some cheaper options would be the GT-40 heads and intake from say a junk yard, ebay or Craigslist. I believe they cam in explorers from 98 And up ( someone correctly if im wrong please ) But you can get those pritty cheap and you will notice a difference in preformance as well. Also i would recommend upgrading your clutch cable, at least in the 85's they were made of a plastic or nylon composite and will strip if your ride the car hard to much. You can pick up a good clutch cable and parts for Around $100. And they are made of steel. But that is only if you have a Manual tranny. Hope this helps a little! Good Luck! |
91 lx convt
14.02@100
headers and o/r H pipe, and +1111111111111111111111111 on tha cylinder heads. please get those gears in.
Heads/cam/intake from Trick Flow
85 GT/86 SVO/2010 GT500
Like Borden said the headers are a must and the gears need to be in asap. you will love what you get out of the header alone.
