Welding 8.8 Axle Tubes
Can anyone tell me the right procedure for welding the axle tubes on my 8.8. I already made a set of axle braces as per some plans from a mustang magazine and they came out great. I just dont want to do anything wrong and maybe warp my axle tubes or somethin like that...
I am not a welder by anymeans by I just read a MMFF and they tell you how I will try to find out which issue it was. We have a shop here in my town that does it cheap though I think he quoted me around 100 for everything that included him making the braces and he guarenteed not to warp my rear end. The keyis heating it up slowly and cooling it down slowly but like I said man I am no welder so I would call around you locally but that is just my opinion. Good Luck Man.
94 Mustang Gt Cold Air Intake Header back exhaust H-Pipe Flowmaster Mufflers MSD Dist UPR upper and lower control arms UPR sway bar all spherical bushing in rear on the way HP Turbo Stage II Kit 331 Long Block |
Let me know thanx bro...
You need to take it to someone that has a jig for welding axles. The one in your car is most likely bent already. Most of them are even with stock engines. Put it in a jig, straighten it and then weld the tubes solid. That is the only way to do it right.
#5 | |
Thats what I thought. Ballpark on what something like that would cost? Are your tubes welded Darrell ?
#7 | |
Gotcha just wanted an idea i need to get it gone we have a frame and axle shop nearby and they have a good reputation i will check them out over the winter... thanx dude
Threads Similar to: Welding 8.8 Axle Tubes
| This guy needs a little welding help. | 06VistaBlueGT | Videos | 18 | October 25th, 2008 05:06 PM |
| welding | terribleonexx88 | 5.0 Mustangs | 0 | September 9th, 2007 06:17 PM |
| welding | terribleonexx88 | Northeast | 0 | September 9th, 2007 06:15 PM |
| Axle tube and torque box welding | Stangzilla | 5.0 Mustangs | 21 | July 6th, 2007 12:13 AM |
| Welding | Horseshoeing | The Clubhouse | 10 | May 21st, 2007 06:08 AM |
