Supercharger
I have a 1989 LX 5.0,with the following modifications: Cobra intake,1.7 rocker arms,70 mm throttle body,73 mm mass air flow sensor,Performance distibutor,MSD box,with new racing coil and spark plug wires.Ceramic coated shorty headers,H-pipe and Flow Master exhaust,without the converters.Under-drive pulleys,racing aluminum radiator,a new performance computer,with a performance tune.The car made 270 horsepower on the dyno,but i would like to have a little more.
What's the best supercharger/turbo kit for my car and will i have to change the current computer in the car,or can i just get another re-tune? Will i have to change the stock 19 lb injectors to 24 lb. injectors? |
#2 | |
well i think HMUSN hit it right on the button.
1993 5.ohhhh
12.97 @140mph
U really dynoed that with just those mods. Sounds like your car has a mild set of heads on the. gt40 or ps.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
Dyno numbers
The car did make 270 hosepower with those mods and it still has the original factory heads installed..
Thanks for you guys taking a look at my questions,but i didn't really get an answer about the supercharger... My car is only driven on weekends and i don't really drive it that much...I am just looking for a "Kick in the Pants" bolt on part... |
well all super chargers will do that. lol
are you looking for top end power or a kick from the start?
1993 5.ohhhh
12.97 @140mph
v2 or v1 strim. 42 lb injectors. 10 pound pulley.
87 Mustang GT T-top
270 with stock heads and intake? You could just upgrade the heads and intake and cam ( H/C/I ). If you want some serious HP.
Or is you want a supercharger do you have a price range? If you want Torque you can go with a roots Supercharger like Kenne Bell. If ya want more top end you can go with a Procharger, Vortech, Paxton. These are Centrifical S/C's and are the Hair Dryer style. Do you still have the original block stock? Or was it rebuilt. If so whats your Compression ratio? |
supercharger
The block is factory stock and the engine has not been rebuilt.The car has 24,000 original miles and is garage kept.I started playing with modifications about 2 years ago and i am just looking for some extra bolt-on horsepower.
After my new computer purchase and the performance tune,i have to run 100 octane gas.The tuner said,running any less octane could cause some engine issues. |
87 Mustang GT T-top
Wow...seems a little ridiculous for only having 270 HP. You have a chip in it? And do you know what the chip is by chance?
But like HMUSN said "are you looking for top end power or a kick from the start?" Also do you have a budget? And/or a HP goal? |
i vote turbo!
but thats just me |
1989 GT
KB 2.1L Flowzilla
Whats your budget? Kenne Bell gets my vote, but it costs a fortune and wont give the most power. Maybe turbo or V2 s-trim would be my second choice.
Wow, 270 on stock heads, un-ported? Thats what, 80hp over stock. But with 100 octane, i dont like that. That much hp could be easily done with pump gas with aftermarket heads. Maybe it is crank hp? Last edited by Arctic Fox; October 27th, 2008 at 11:49 AM. |
1993 5.ohhhh
12.97 @140mph
If your car makes those numbers it the way it does now, a good hci would ride out. Some twisted wedge heads, tfs intake and a custom cam youd prob be a nice low 12 second car.
#14 | |
1991 Mustang GT
i am interested to know how much for that set up ? just curious
Vortech polished S-trim supercharger (Part number VOR-4FA218-048S $3100 new) and Vortech polished air to water aftercooler (part number vor-8N301-018 $2000 new). This is a complete kit ready to bolt on and go including boost retard, all brackets, pulleys, belt, 2.95 and 3.33 supercharger pulleys, upper radiator hose, power pipe, water tank, plumbing, heat exchanger, instruction manual, etc. This set up made 15psi with the 2.95 pulley on a mild 306. Also included is a Pro M 80mm mass air meter, Ford Racing 42lb injectors and a Diablo Sport chip tuned for this set up. Very low miles on everything. - $2900
Bolt it on and go.
1991 Mustang GT
damn nice setup ..... i am just a lil bit to poor lol but that will make some lucky guy very happy
87 Mustang GT T-top
Dang Darrell, how much HP were you putting out with that thing? With the S/C 15lbs pulley + the aftercooler. I bet that thing screamed!
Supercharger for sale
That sounds like a killer deal....I have a few questions to ask...
My car only has 24,000 original miles and i don't abuse it when i drive it.Would that kit be compatible with my car,since everything is still basically stock? I don't want a supercharger that is going to "kill" the block,bend,or break a rod,or damage the valve train.This motor stops pulling around 4700 rpm,so it's not a high rpm monster motor. I would like to find a simple,bolt-on kit,that will give me good throttle response,better low-end torque,without destroying the motor.I plan on keeping the car for a while longer and i don't want to mess up the reliability,or the drivability. |
#20 | |
Threads Similar to: Supercharger
| help with supercharger please!! | carlos | 99-04 | 17 | July 17th, 2008 05:03 PM |
| Supercharger | pa.ulB | General Tech | 16 | February 8th, 2007 06:49 AM |
| supercharger | Mustang RacR94 | 99-04 | 2 | February 2nd, 2007 02:12 PM |
| Supercharger | Mustang RacR94 | Modular Mustangs | 1 | February 2nd, 2007 11:28 AM |
| supercharger | Kennhyy3 | V6 Mustangs | 27 | January 29th, 2007 10:25 PM |
