seafoam / pcv
Old October 26th, 2008, 07:45 PM   #1
Hunt_chevs's Avatar
2002 Gt
Not Slow
seafoam / pcv
where is the pcv located under the engine bay,.. i know it feeds to the lower intake in the back but wheres the other end,... im tryna seafoam
Old October 26th, 2008, 07:52 PM   #2
Hunt_chevs's Avatar
2002 Gt
Not Slow
and do i need to change my oil immediately after doing it? i honestly dont feel like doing that for a few days,. the oil is rather new
Old October 26th, 2008, 08:00 PM   #3
looking to buy sn95 5.0
MaPolley07 is on a distinguished road
Why are you set on using the PCV? I usually run seafoam through any vacuum line high up in the intake manifold/plenum, but past the MAF and Throttle Body on most cars. I want it to go through the entire motor
Suck 1/3 to 1/2 a can up through one of the vacuum lines, shut off the car for about 10 minutes and run it until the exhaust stops smoking
1/2 can or so in a full tank of gas, and 1/3 can or so into the oil
drive about 100 miles and change the oil
Old October 27th, 2008, 10:56 AM   #4
did my reply help you out? It would be a good idea to replace the PCV valve while you're at it, but you don't have to run the seafoam through the PCV necessarily, a vacuum line high up in the intake manifold is best from my experience
Old October 27th, 2008, 10:59 AM   #5
fateisajester's Avatar
1989 Ford Mustang
3 mins
fateisajester is on a distinguished road
Send a message via AIM to fateisajester
I always use my break booster line. its just as good a the pcv, and alot easier to get to imo
Old October 27th, 2008, 11:15 AM   #6
e3sean's Avatar
1988 lx
9.68@142
i like to use a turkey baster and squirt it into the throttle body directly....
j/k
<font size=4><b>MILITARY CREW
Old October 27th, 2008, 03:16 PM   #7
Hunt_chevs's Avatar
2002 Gt
Not Slow
from the searches i did, most of the people on here recommend the pcv,...
Old October 27th, 2008, 03:18 PM   #8
Hunt_chevs's Avatar
2002 Gt
Not Slow
also, how critical is it to change the oil ? I might just wait to seafoam because my oil is relatively new, i just changed it a couple hundred miles ago,.. so i dont plan on swapping for about another 1k
Old October 27th, 2008, 03:20 PM   #9
1992 Lx
11.39@119.24
the pcv is in the lower intake mani and the vacuum off it runs to the upper plenium
Old October 27th, 2008, 03:21 PM   #10
Sleeper_Stang_89's Avatar
1989 Mustang Gt
Run me and find out!!!
Sleeper_Stang_89 will become famous soon enough
what I was told was if I put it in my oil that changing the oil soon was critical because of all the garbage that might start floating around or something like that, but I dont know how true it is... Ive never ran seafoam in my oil I just use the vacuum lines, brake booster and PCV
331 ways to WASTE an LS1...
I love pink
Originally Posted by sgrcltpunk View Post
dont fuck with bad pussy
Old October 27th, 2008, 03:31 PM   #11
Well Seafoam will break down the oil, i usually put it in my oil about 100 miles before changing the oil
The next oil change your oil will come out a lot cleaner, i only seafoam about once every 2-3 oil changes, and when i do, i do vacuum, gas, and oil
Old October 27th, 2008, 04:20 PM   #12
Chris951's Avatar
1991 mustang 5.0
Chris951 is on a distinguished road
Brake Booster.
Old October 27th, 2008, 09:03 PM   #13
Originally Posted by Chris951 View Post
Brake Booster.
I agree, brake booster vacuum lines work perfectly on just about every car I've ever seen
Old October 27th, 2008, 10:17 PM   #14
nolife's Avatar
91GT, 88GT, 02GT
I've always been a little skeptical about using any type of motor flush. My fear is not based on experience so I could be totally wrong here. Driving around for 100 or so miles or breaking up what might be in there and allowing to collect or go somewhere else does not seem like a good idea. It seems like one of the last resorts when you actually have a problem, not something you would want to do just because. Some cars DO have known sludge build up issues but the 5.0 is not one of them. It would be interesting to do a before and after look at the oil pan and oil pickup area after doing one.
Old October 27th, 2008, 10:43 PM   #15
-Joeyy- is an unknown quantity at this point
Send a message via AIM to -Joeyy-
yeah do it off the break buster line its on the right of the engine bay when u pop the hood
Old October 28th, 2008, 09:08 AM   #16
1989 Ford Mustang
3 mins
nuff said
Old October 28th, 2008, 09:36 AM   #17
The main use of Seafoam is to clean all the crap out of the motor. Running it through the vacuum lines cleanes out carbon deposits, in the gas cleans the fuel system and injectors, and in the oil will clean sticky lifters, minor sludge build-up, etc.
Threads Similar to: seafoam / pcv
PCV location question (pics inside) / Seafoam warrior86 V6 Mustangs 11 August 10th, 2008 11:52 PM
PCV wraitherx 4V / SVT 0 May 2nd, 2008 01:15 PM
PCV mmvi V6 Mustangs 23 December 28th, 2007 11:38 PM
PCV RyanGT 99-04 9 December 18th, 2007 05:03 PM
PCV Bill 5.0 Mustangs 2 August 20th, 2006 03:55 PM
