Weld Draglites
Old January 2nd, 2006, 02:18 PM   #1
max5.0 is on a distinguished road
Weld Draglites
looking to buy a set of rear 15x10 weld draglites for my 1984 mustang 4 lug but do not know what back spacing to prevent rub will fit can somebody please help?
Old January 2nd, 2006, 04:32 PM   #2
88 Mustang Coupe
www.rickscarcare.net
Old January 2nd, 2006, 04:39 PM   #3
Do I Need to do any mods.
Old January 2nd, 2006, 06:00 PM   #4
depending on the height of the tire, it may hit on the inner frt wheel well. If so, clearance w/ bfh. Also may be close to the outer fender lip, depending on height, if so, the edges will be to be rolled under.
88 Mustang Coupe
Old January 5th, 2006, 09:06 PM   #5
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
You will need to clearance the inner fender well. A big hammer will do the trick. Heating with a torch helps alot while hammering.
Old March 14th, 2007, 11:36 AM   #6
1990 5.0 LX Notch
flamed 98 gt is on a distinguished road
What size tire can you fit on them???
Old March 14th, 2007, 03:29 PM   #7
5-0stank is on a distinguished road
I <3 BFH mods.
1995 GT::Sold!
Looking for another stang...
Old March 14th, 2007, 06:56 PM   #8
Moderator
89StangGT's Avatar
SVT Cobra Mustang
89StangGT has a spectacular aura about89StangGT has a spectacular aura about
Send a message via AIM to 89StangGT
you going with slicks, radials, street slicks, or normal street tires?
There's a reason Ford codenamed them the Terminator
Old March 14th, 2007, 09:35 PM   #9
1990 5.0 LX Notch
street slicks
Old March 14th, 2007, 09:49 PM   #10
Moderator
89StangGT's Avatar
SVT Cobra Mustang
depending on gear and how low your car is, you can fit a 26x11.5-15 ET street, or a 28x11.5-15 ET street without any problems.
Threads Similar to: Weld Draglites
draglites ??? paul 2005 - 2010 6 January 11th, 2007 05:20 PM
