88 mustang GT
interesting article, could fix idle surge?
my dad came across this and sent it to me.
FORDMUSCLE webmagazine: Fixing the 5.0L Surging Idle - Ten Pin Connectors i just got done following the instructions as well as putting some dielectric grease on and i zip-tied the connectors together for good measure. not sure if it will make a difference till i drive tomorrow. but for 15min of my time it seems worth it. |
1992 Lx
11.39@119.24
my surging idle was because a vacuum line that goes from the vac tree to the upper plenium fell off
88 mustang GT
well surging idle can be any number of things. i just thought this was something that could work that i hadnt heard of before.
1988 Mustang 5.0 LX
12.48@118.27
Does your engine have to be warm in order for it to surge on a vaccum leak
88 mustang GT
if its vacuum it would likely do it all the time. it wouldnt hurt to check all your vac lines though
#6 | |
sweet...i dont have idle issues but im gonna do it anyways next time im bored
1988 Mustang 5.0 LX
12.48@118.27
the bracket that holds my salt and pepper shakers to the plenium is broken. probably when the previous owner decided to change the intake to a GT40 cobra intake
88 mustang GT
so is mine i just broke it off cause it was being a pain in the ass. but after i did the fix i just tucked them away so they couldnt be seen as well
88 mustang GT
1991 mustang 5.0
I just did this. It definately helped some. I still have a little surging but I need to set my tps voltage. My car would surge really bad when in second at ~1200rpms. I can hardly notice it now. good article.
Threads Similar to: interesting article, could fix idle surge?
| Interesting Article | ReverendDexter | The Clubhouse | 6 | September 26th, 2008 12:44 AM |
| help idle surge! | bambam88 | General Tech | 1 | July 9th, 2007 03:58 AM |
| Idle surge | izze01 | 5.0 Mustangs | 1 | July 1st, 2007 02:32 AM |
| help idle surge! | bambam88 | General Tech | 1 | April 11th, 2007 12:26 AM |
| idle surge | slow98gt | 96-98 | 8 | February 12th, 2007 04:56 PM |
