LinkBack (1) | Thread Tools |
#1
1986 mustang GT T-top
need advice
OK this weekend i took my car to a guy that knows mustang . He has a 92 gt with a vortect superchager blah blah blah but he did all the wrok him self so i knew he could help me get my car to stop running so rich He nottiched that i had some vacuum lines were really old and that they some have broken and then he said that something was umpluged to my smog pump
we both didnt know it was but heres the part # i got from it E4TF-9C915AA So does broken vacuum lines and a f uped smog pump sound like a good reason for my car to run rich |
87 Mustang GT T-top
Do you have an aftermarket cam? Or any mods? A cam made mine run rich.
Im honestly not sure about the Vacuum lines but i know for me atleast an aftermarket cam made mine run rich. Also how long have you owned the car? maybe the pervious owner had it chipped, did you check the computer at all? What mods do you have on the car now? |
alll i did to that car a was a cat back exhaust and a cold air intake
i have onwed the car for 6 months and it has alway run rich but the guy before me said that guy was making it into a dragster and but then got another project so i really dont know excatly what was done to it |
87 Mustang GT T-top
Well it could be possible you have a Cam upgrade.
#5 | |
1993 5.ohhhh
12.97 @140mph
You will know for sure if your cars cammed. Can't mistake it for anything else, minus a huge MIS.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
ok one guy that drove my car said it had more pep compared to his stock 87 gt and so mabye it does have a cam upgrade
so is there any way to try to get the smoke and smell down with out getting a new camshaft |
1993 5.ohhhh
12.97 @140mph
Some bolt on foxes run low 13s and others high 15s. Do you have an idle video? I have an fcam and when my car starts up, it cams hard as shit... its more then ovbious.
what does running rich mean exactly?
1993 5.ohhhh
12.97 @140mph
to much fuel.
ok ill try get a video of my id
even if is a different cams is there any ways that i can get the smell and smoke down. Would a new mid pipe help ? |
ohh ok thanks.
87 Mustang GT T-top
You have smoke too? What color and how long does it stay around, or is it just start up, or everytime you get on it, or at all times?
vacume lines worn or broken on most vehicles can cause them run rich i have no smog equipment on my car perioud lol and it runs great, and as far as the cam goes you either have one and its loapin may be even rockin the car at lights dependin on the cam or like what was said ya have a huge miss, but most engins missing that bad tend to wanna spit and or try to cut out at hard accelerations, just been my experience anyways
#15 | |
and when im sitting at a red light the form what i see the smoke is white |
#16 | |
WTF y cant my car just run right
is it converted to maf? a vac leak on a maf car would cause it to be lean.
It sounds to me like you have a foul o2 or stuck injector. Try tapping on the injectors LIGHTLY with small screwdriver, one might be stuck.
weeee foooord!
how would i tell if my injectors are stuck
1993 mustang lx convertib
do you know what size your injectors are if not what color are they that will help you figure out the size also what is the fuel pressure at some guys used to remove vacuum from the pressure regulator to make more pressure to get more out of the car that's OK if you have a stock pump but if you have a 190 or 255 pump in the truck you will have way to much pressure
#20 | |
weeee foooord!
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/94985-need-advice.html
| need advice | This thread | Refback | October 28th, 2008 03:11 AM | |
Threads Similar to: need advice
| Need advice... | ~C~ | The Clubhouse | 7 | July 8th, 2008 08:38 AM |
| some advice please | GTblackprodigy | The Clubhouse | 15 | February 4th, 2008 03:58 PM |
| New '96 GT need some advice | S10-92V8 | 96-98 | 13 | October 31st, 2007 11:21 PM |
| advice about 4.10 and a S/C | andoutcomethewolves | V6 Mustangs | 14 | February 6th, 2007 09:35 PM |
| Need some advice... | 97stangman | 96-98 | 6 | January 19th, 2007 04:23 PM |
