LinkBack (1) | Thread Tools |
#1
1979 mustang 5.0
hopefully 11's when complete
need help choosing throttle cable
Ok here's the deal, I have a 79 mustang with what as Far as i know is the stock cable. I put a holley 700cfm double pumper on my 351w. When the pedal is on the floor you are only opening like 1/3 of the throttle on the carb. The shop says I need a new different cable. I know I'm not the first guy to put a holley double pumper in a fox mustang V8, So what cable should i get for my application guys?
thanks, -Devin
1979 hatchback: -351w w/ 10.5:1 -Tremec TKO |
What are you using for a throttle bracket? On all of my carbureted cars I use an 85 Mustang GT manual transmission throttle cable and an AED throttle bracket. Never had a problem.
1979 mustang 5.0
i think the stock bracket. But I don't think it's the bracket because the cable is all the way out as much as it can be, then you put the pedal to the floor and you only give the carb 1/3 throttle. The guys at the shop said they adjusted it as much as they could, still not even close. So I'm guessing I need a longer cable?
#4 | |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/95111-need-help-choosing-throttle-cable.html
| need help choosing throttle cable | This thread | Refback | October 28th, 2008 10:00 PM | |
Threads Similar to: need help choosing throttle cable
| Throttle Body Cable Sticking | AggieStang | 99-04 | 15 | December 6th, 2010 06:10 PM |
| throttle cable | db83stang | 5.0 Mustangs | 1 | January 26th, 2008 02:39 AM |
| Throttle Cable Tightening | dgt_mustang | V6 Mustangs | 7 | November 10th, 2007 04:53 PM |
| throttle cable mod | 93fourbangerstanger | 2.3 Mustangs | 30 | September 13th, 2007 03:42 PM |
| Throttle cable..loose | Timmano | V6 Mustangs | 4 | May 5th, 2007 04:51 PM |
