351W questions
Old October 28th, 2008, 07:25 PM   #1
1985 Mustang GT
viperlocc is on a distinguished road
351W questions
So I found 2 351W engines for VERY cheap. One is from a '80's van and the other was unlisted. Will the 351W fit in a '85 mustang, no matter what the 351 is pulled out of? (i.e. van, truck, etc...)
Will it also bolt up to my 5-speed transmission, and will the cam from the 302 work in the 351? (im thinking no but had to ask)
already know the flywheel will work, heads will work. Think i might do this route rather than rebuild the 302
Old October 28th, 2008, 07:54 PM   #2
-Joeyy- is an unknown quantity at this point
Send a message via AIM to -Joeyy-
yeah the 351w will fit
Old October 28th, 2008, 08:12 PM   #3
MSO
MSO is a jewel in the roughMSO is a jewel in the roughMSO is a jewel in the roughMSO is a jewel in the rough
Send a message via AIM to MSO
i believe the engines use the same engine mounts so it should fit right in, there might be some clearance issues, like with the hood for example
[SIGPIC][/SIGPIC]
Old October 28th, 2008, 08:18 PM   #4
92sspnotchback is on a distinguished road
You will need swap headers and oil pan. Also check to make sure you have the correct balance flywheel for the 351W.
Old October 28th, 2008, 08:22 PM   #5
the 351w is a bit wider i believe and mine just barely fits in like maybe you can fit 3 penny's in between the headers and the engine bay. but you should be fine.
Old October 28th, 2008, 09:08 PM   #6
1985 Mustang GT
What do you think it will take to make a 460 fit lol
Old October 28th, 2008, 09:16 PM   #7
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
460s drop right in too. You will need engine swap headers, oil pan and engine mounts. You will need a strong transmissioin too.
Threads Similar to: 351W questions
351w fox track questions skidze 5.0 Mustangs 13 September 28th, 2008 01:18 AM
351w questions laztug 5.0 Mustangs 6 July 18th, 2008 11:42 PM
351w questions fastlane_24 94-95 1 June 12th, 2007 11:50 PM
351w questions fastlane_24 94-95 6 June 9th, 2007 04:50 PM
351w questions javier351lx 5.0 Mustangs 2 June 6th, 2007 12:52 PM
