quick rear question
my friend has a stock rear in his mustang i think it is lsd not sure ( when u spin one tire the other goes in the opposite direction and it has 3.43 gears or some thing.
he bought a another rear with locked diff or posi or what ever and it has like 2.73 gears im just estimating the gears i am not 100% sure it is that. He is wondering if its worth changing the rear? but he wants both tires to spin when he burns out 99% of the time. is it easier to swap the gears then put in 3.73's then to convert his limited slip to locked diff/posi please respond asap hes waiting on the reply thanks guys. |
cmon guys i need help
48.47@ 12.58
what year is his stock mustang? and is it a v8 or a v6?
88 mustang GT auto t-tops
#5 | |
All 86 and up Mustang GTs come with a traction lock differential from the factory.
The traction lock is burned out and needs to be rebuilt.
so what should he do have his current rear rebuilt or just put in this other older rear that is posi and just upgrade the gears? or just take a 1.0 gear ratio loss by swapping. sry if this sounds a bit confusing
![]() p.s. he already purchased this new rear. |
#10 | |
Your buddy can rebuild his traction lock. The parts cost about $60.
#11 | |
ohh ok what is the difference between open, limited slip, and spool? i know spool is full power to both wheels 100% of the time. wait i think i get this just correct me if im wrong i am using the term posui to refer to both tires spinning and that is wrong so what term do i use locked diff? Last edited by -Joeyy-; October 29th, 2008 at 08:51 AM. |
85 GT/86 SVO/2010 GT500
Not sure what you have
Even if the trac-loc is burnt up, the tire will spin the same direction so you must have the wrong diff in it . take the other rear you bought put new gears in it (3.73-4.10) don't forget friction mod aditive and put it in.
#13 | |
A limited slip (or whatever other of the 1000 names it has including posi) has clutch packs or another mechanical device in it that applies power to both tires. The limited slip type differentials also allow the tires to spin at different speeds when turning corners so axles don't break, tires don't wear out, etc. A spool is a fully locked rear end. Both axle shafts are connected to a solid device that locks them together. The axles will always spin at the same speed. Not recommended for street use, especially if you don't have aftermarket axles.
#14 | |
thanks a lot tho bro for the reply
#15 | |
ok i think we are on the same page now thanks for clearing that up. My friend has a open diff because when we jack the car up and spin one tire the other tire spins in the opposite direction. my friends right tire is bald as a Q cumber and his left looks like new. |
#16 | |
As far as the wheels turning in opposite directions, I had a rear end that I thought was an open rear end once because the tires turned in opposite directions. I opened it up and it was indeed a traction lock that was burned out. So that bit of information about traction locks always spinning in the same direction is not correct.
The only way to know what you have is to pull the cover off and verify.
ok but all this work... you dont think it would be easier to just swap the rears and upgrade the gears?
he would want to upgrade the gears in his stock rear any way. |
Darrell is correct the only wat to be 100% sure is to look and the chance that a GT car has a open rear end is pretty slim so get gears and a clutch kit and go to town
What happens if the other rear end needs to be rebuilt? Then you have to do the work anyway. Swapping gears is harder than rebuilding the traction lock. If it was me I'd rebuilt it so I know it is good.
Threads Similar to: quick rear question
| alright quick quick light tint question | thorpedo26 | The Clubhouse | 18 | September 1st, 2008 07:36 PM |
| quick rear end question | ByPopularDemand | V6 Mustangs | 1 | August 14th, 2008 10:25 PM |
| quick rear brake question | DeMello | 99-04 | 21 | June 13th, 2008 11:12 PM |
| Quick Rear end question! | TheBrat | 5.0 Mustangs | 13 | February 18th, 2008 11:32 PM |
| Installing Rear Gears, Quick Question | OcOnnor220 | 99-04 | 12 | October 9th, 2007 09:36 PM |
