crank ?
I'm rebuilding my engine and the crank is just within specs. Do you guys suggest leaving it or getting it ground. The crank looks great. Just trying to get some opinions.
You gotta measure the inner diameter of the main bearings installed in the caps. Then measure the outer diameter of the crank, subtract the two and see if you are comfortable with the bearing clearances.
+1
Yep, what Woody said.
Threads Similar to: crank ?
| Crank but no Spark. | noyz25 | 5.0 Mustangs | 5 | July 23rd, 2007 10:59 PM |
| 351w with a 302 crank? | 68351w | Classic Mustangs | 4 | July 4th, 2007 01:29 PM |
| crank pulley | mikedoogen | Modular Mustangs | 3 | June 20th, 2007 02:22 AM |
| crank pulley help | mikedoogen | 2005 - 2010 | 3 | June 19th, 2007 02:17 PM |
| No crank, manual...Need help | Modified88Dreamer | 5.0 Mustangs | 4 | January 10th, 2007 12:00 AM |
