1993 Mustang
we'll find out when i come home from iraq.
4cyl to 5.0
can you use the tranny from a 4cyl on a 5.0? also what else do you have to do for the efi conversion
1990 Mustang GT
13.64 @ 101 MPH
i know somebody who ran a 4cyl t-5 on a 5.0 with 200 shot for a lil over 2 years. just gotta swap the bellhousing to a SBF style. also you will need wiring harness and ECU
![]() 90 Ford Mustang 5.0 T5- BROKE 1.9 60' on street tires13.64 @ 101 MPH 89 Ford Mustang coupe- http://www.youtube.com/watch?v=1nIrzcQz3_8 |
4 cylinder T5s are weak and have gear ratios intended for a torqueless 4 cylinder. They suck behind a V8.
91 lx convt
14.02@100
it will work if your jus driving around town but if your planing on putting down power then the v8 is a must.
yeah gearing sucks balls.
I'm going to run my 4 cyl trans until spring so i can get the clutch and motor broke in. you need: sbf bellhousing for t5 clutch fork 5.0 mounts fly clutch different pilot bearing for 4cyl trans > 5.0 thats it.
weeee foooord!
1993 Mustang
ehh i think ill just find a v-8 lol
91 Mustang LX Fastback
We shall see when she gets done..
So, lets say you want to swap over a 5L with a carb on it? Do you still have to swap over the main ecu and 5L harness? Or can I just use the 4cyl harness and computer??
Brett!
2003 MazdaSPEED Protege. Lava Orange with all the go fast parts 1991 LX. 2.3T in the works. 1977 Pinto Wagon. New motor combo in the works for 2012, C4, 4.10s, 150 pill. Et. unkown ![]() 1969 Impala. Needs a resto. Im Canadian, Eh! |
12.8@103... stock motor
11.8@113...150 shot
if its a carbed motor then you can rip the wiring and computer out and throw it away, then just wire everything you need power to...
Well than, that saves me a great deal of issues...
So, I just need to swap the trans member, motor mounts, and thats about it... Is there anything else I should look out for? Thanks. Brett!
1986 lx notch
9.98 @ 135
trannys are wierd, i've broken " world class " trannies in 12 sec cars, yet had a 4 cyl trans live for 2 years in a 13.0 car on et streets ( the slicks not radials ) powershifted every day . i didn't put the trans in so i don't know what pilot bearing to use
![]() " Spending money I don't have.... on things I don't need .... to impress people I don't know " . |
Alright, well, I guess this raises another question.
The 5L I got is out of I beleive a 86 Thunderbird. I got a carb, intake, and distributor out of I beleive a 79 or 80 Fox that had a 5L.. Will that stuff work together? Or do I need to go shopping? Brett!
my friend used his t5 out of a thunderbird for a year and a half on an 11 sec car. go figure. nuked his v8 wc in one month.
weeee foooord!
1988 lx t-top
if the motor is a roller motor the gear on the distributer will have to be changed also dont forget you will need an inline fuel pump about 15 psi the efi is to much
I always thought if you used a smaller part on a big part it would just demolish the smaller part...
I always try to keep it simple and save the hassle but it seems some have got this to work before... Your call. |
1986 lx notch
9.98 @ 135
if it is a roller then the thunderbird motor has a different firing order then the mustang motor ( don't ask me how i know )
my boy put a junkyard short block out of a cougar ( same as t bird ) in his mustang and sprayed it into the low 11s ( used a bottle every week ) and it lived for a long time + 1 on the distributor gear
![]() " Spending money I don't have.... on things I don't need .... to impress people I don't know " . Last edited by 86_Notch; November 3rd, 2008 at 07:51 PM. |
Threads Similar to: 4cyl to 5.0
| 4cyl -> 5.0 f.i. convesion ? | superbean | 5.0 Mustangs | 6 | September 19th, 2008 06:39 PM |
| What's needed for 4cyl to 5.0? | alabamastanger | 5.0 Mustangs | 9 | March 19th, 2008 06:33 PM |
| 91 4cyl | '91'mustang | V6 Mustangs | 4 | July 5th, 2006 12:41 PM |
| 4cyl exhaust help | vixen | 2.3 Mustangs | 3 | June 24th, 2006 01:37 PM |
