1991 mustang 5.0
surging and running RICH
So I just got my 302 back together after a topend rebuild/cleaning. I put on a 70mm throttle body while I was at it and started it up and the car will not idle. It sounds like it has a HUGE cam in it. It goes down to like 500rpm and jumps to 900 like every second. And when I'm driving it, it will surge real bad when I'm under or at 2k rpms in any gear and it sounds like it's missing when i drive it.. And there is white smoke coming from the exhaust and it smells so rich in the car me and my friend got all lightheaded and felt like we were going to pass out lol. What could be the problem?
Sounds like a major vacuum leak but the possibilities are endless. Start by pulling codes and checking for vacuum leaks.
or even a bad injector(s)
EVERYONE IS ENTITLED TO MY OPINION:cool: 6'ers are for kids 1965 chevelle SS 421 sbc 6 speed, 3.90 gears,alum d-shaft, brodix heads,roller cam,925 AED carb...grocery getter*[COLOR="Red"]RIP[/COLOR]* |
1991 mustang 5.0
this all happened after I replaced the upper intake manifold and the throttle body though and the car is speed density
1991 mustang 5.0
The "S" vacuum line off the tree to the intake mani has a crack but I do't think it's big enough to make my car run like total shit. I parctically replaced all the vacuum lines because almost all of them broke.
1992 Lx
11.39@119.24
are your little caps still on all of your injectors?
1988 lx
9.68@142
have you checked your tps sensor?
1991 mustang 5.0
1991 mustang 5.0
1991 mustang 5.0
and whats crazy is it runs like a BEAST under WOT but just under normal driving it runs like shit
95 opalfrost gt
Did you pull codes yet? Did you check the TPS voltage?
If it only runs good at WOT then I would suspect bad 02s as they are ignored at WOT and used at idle and part throttle. I would also replace that cracked vac line.
1988 lx
9.68@142
that doesnt mean its not sending out the wrong voltage. put a volt meter on it with KOEO (key on engine off) + to the green wire and just ground the - and it should be sitting anywhere from .96-1.0 volt in resting position then high 4.** volts at WOT
my buddy just switched 3 of these in his car cause it was doing the same as yourse is doing it was sitting at 4.** at idle and WOT then we found out it was the computer. we put mine in it and it ran like a dream this was like 3 days ago.. i am not saying this is it but since it was sending the fuel in for WOT all the time it ran great at WOT then way rich in every other power range.
1991 mustang 5.0
vacuum line wasn't connected to the map sensor. Runs great now lol
im happy to hear that
1988 lx
9.68@142
nice
Threads Similar to: surging and running RICH
| Running rich so rich it smokes like BBQ | hkaiser83 | 5.0 Mustangs | 7 | September 21st, 2008 11:10 AM |
| Running rich | 86gt t-top | 5.0 Mustangs | 11 | September 12th, 2008 10:06 PM |
| Running awfully rich??? | shurb125 | 5.0 Mustangs | 19 | August 29th, 2008 07:14 PM |
| running just a little rich | mxnate116 | 5.0 Mustangs | 0 | May 24th, 2008 06:39 PM |
| Running Rich | Naytoo | 99-04 | 1 | April 26th, 2008 04:41 AM |
