#21 |
1990 mustang gt
n/a
Sorry, I misspoke on your code 67, it was late last night when I replied. Code 67 could be clutch switch circuit failure or Neutral Drive Switch (NDS) circuit open A/C input high. The MLP is Manual Level Position sensor and is on the 4.9L and 5.8L engines. The NDS provides a signal to the PCM to inform it of the shifters position. If this is open, it tells the PCM the tranny is in reverse or drive. So, if there is a fault in the circuit such as an open circuit the PCM will think the car is in gear even if it is in neutral. The computer uses this signal to control idle speed.
Threads Similar to: My 5.0 runs like poop when its cold. Please Help
| Poop Freeze! | Vinyl66 | The Clubhouse | 6 | June 24th, 2008 12:27 PM |
| How to Poop at Work | WAR-PARTY | The Clubhouse | 3 | May 29th, 2008 02:14 PM |
| How To Poop At Work | Black02GT | The Clubhouse | 15 | April 15th, 2008 11:17 PM |
