My 5.0 runs like poop when its cold. Please Help
when i first start the car it runs strong for like 1 minute or so. Then it starts to act funny till it warms up. By funny i mean i give it partial throttle and it sputters and backfires and barely accelerates. But if i put the pedel to the metal it runs hard WOT. and this happens everytime and last till it warms up. When it warms up and runs normal it does'nt for some reason run as hard/fast as it does when i first start it before it starts to act up.
Any and all help very appreciated. |
did you try seeing what codes its throwing yet?
same promlem here... does your seem like it backfires/misfires and sputters part throttle when cruising???
2000 V6 Performance Red @ Cardomain Was fun but a waste... 1987 LX Hatch | Soon to be a 600hp monster |
1990 LX hatch
could be a vaccum leak. they are more identifiable during idle, and part throttle. spary carb cleaner on your vaccum lines and see if the idle rises.
Atomized
carbed or efi?
The Hammer
Millenium Falcon
stop refueling with feces
EFI 5.0 HO... my car backfired pretty big today i thought i blew something up, seems to run pretty good for the time being LOL
1988 lx t-top
your throttle body isnt closing, try holding your hand over the throttle body so only a little air gets in when its cold
just let it warm up.
2002 Gt
Not Slow
wouldnt there be an intake connected to the tb?
2k2 Gt Eibach pro kit, bbk cold air, exhaust, 4.10s, 6k hid's |
yeah i have a prety wicked 93 octane tune on my car and its really rough in the morning when its cold...but i let it idle for 5 minutes and it runs like a dream. if you have your timing bumped way up that is probbaly why
#12 | |
weird thing is though when i very first start it it runs fine then after a minute or so it starts acting up then after a couple minutes it stops and runs fine again. |
timing is at 11 btw.
Thats what mine did once i bypassed the coolant lines going to the EGR spacer by my throttle body. as soon as it warmed up it was fine. do you guys have your egr coolant lines bypassed??
- '90 Mustang LX-Sold "Debbie" - '89 Mustang GT- Deceased "Lucy" - '91 Mustang GT-70,000 mi "The Unicorn" |
If your talking about that line that is going to the EGR spacer that the egr is attached to on a stock mustang manifold. Then yes mine is blocked off cuz i have GT40 upper and lower. Plus i have no vacuum line going to the egr either. If this is the problem how do i fix it?
remove EGR and smog pump from your car and get an EGR spacer. why is your timing at 11? bump that **** up to 14!!!
54 - ACT sensor circuit open
67 - MLP sensor out of range or A/C on (E4OD) 81 - Air management 2 circuit failure 82 - Air management 1 circuit failure 85 - Canister purge solenoid circuit failure 87 - Fuel pump primary circuit failure |
this is because you have a canned tune that can't adjust for a cold start..
EVERYONE IS ENTITLED TO MY OPINION:cool: 6'ers are for kids 1965 chevelle SS 421 sbc 6 speed, 3.90 gears,alum d-shaft, brodix heads,roller cam,925 AED carb...grocery getter*[COLOR="Red"]RIP[/COLOR]* |
1990 mustang gt
n/a
67 - MLP sensor out of range or A/C on (E4OD) 81 - Air management 2 circuit failure 82 - Air management 1 circuit failure 85 - Canister purge solenoid circuit failure 87 - Fuel pump primary circuit failure I would start by checking the ACT, it is screwed into the intake manifold on the driver's side near the front. The ACT measures air temp inside the mainifold and helps adjust air/fuel ratio and spark timing advance. If it is open, like the code says, it will show infinite resistance which tells the computer that the air is extremely cold and will richen the air/fuel mixture and advance the timing. Check to make sure it is plugged in. Also, test the resistance it should read 29 kilohms at 77 degrees. I am not sure what the MLP sensor is but a 67 code is neutral drive switch or circuit, or A/C clutch circuit fault. I don't think your A/C compressor clutch is the problem. Mine is not even hooked up and I don't have an idle problem. Try unplugging it though and see if it helps. I am guessing that you have an A/T. If this is the case your PCM controls the torque converter lockup clutch. Certain parameters must be met for the converter to lockup and to unlock. If the lockup solenoid is not activated or deactivated at the right times then it could cause idle and drivability problems. As for codes 81, 82, and 85 I am also guessing you don't have the AIR system hooked up. This will trip codes in the PCM but should not cause idle or drivability concerns as long as you plugged all of the connections so there is no vacuum leaks. I also don't have an AIR system. Just make sure all the holes are plugged. Code 87 fuel pump circuit, this could obviously cause idle and drivability issues. Test the circuit visually for loose or corroded connections also perform voltage drop and resistance tests. If she is not getting the fuel she needs she won't run properly. I would definitely start with the ACT sensor. This sensor helps control advance (too much in this case causing a back fire) and air/fuel mixture (too rich in this case causing a poor idle). Then check the fuel pump circuit. |
Threads Similar to: My 5.0 runs like poop when its cold. Please Help
| Poop Freeze! | Vinyl66 | The Clubhouse | 6 | June 24th, 2008 12:27 PM |
| How to Poop at Work | WAR-PARTY | The Clubhouse | 3 | May 29th, 2008 02:14 PM |
| How To Poop At Work | Black02GT | The Clubhouse | 15 | April 15th, 2008 11:17 PM |
