Strange Idle
Well my car was not idleing correctly so i did the base idle reset and it idles great now, except for one thing. After its been running for about 5 mins, it will idle up at 1600 and not go back down. i have to restart the car in order for it to idle correctly again. At first i though it was just the computer trying to learn the new idle set up but its been a few days now and its still doing it.
any ideas?
12.9 @ 105
Check for a vacuum leak and look at your IAC motor.
1988 lx
9.68@142
thats been happening alot lately. the most common things. vaccume leaks,iac bad or dirty,computer bad,tps sensor off,o2 sensors,timing, it is getting colder the temp could have something to do with it.
#4 | |
it does it with the a/c off so not the iac possibly a bad ecu but doubt it tps is at .99 i dont know how to check the o2 sensors timing is at 12^adv I live in florida and its still getting in the 90s the strangest part about the whole deal is when its idling bad, I can turn the key off and on real fast(just enough to kill the ign for a split second) and it startes idling fine again. I freaking hate efi!!! anyone else have any ideas? ::edit:: btw, i ran the codes on it and only got smog related codes.
1991 hatchback Gt
I got the same problem on my 91 I can't figure out what the problem might be, got new IAC, oxigen sensors, new vaccum lines, tps sensor and the problem still there.
Well im going to pull the tps today and try to clean it. maybe that has something to do with it.
i would say it probably is ur ecu or the oxygen sensors. If it dosent go back down after you clean your tps the check your ecu. It also might be a compter problem.
clean the egr valve
EVERYONE IS ENTITLED TO MY OPINION:cool: 6'ers are for kids 1965 chevelle SS 421 sbc 6 speed, 3.90 gears,alum d-shaft, brodix heads,roller cam,925 AED carb...grocery getter*[COLOR="Red"]RIP[/COLOR]* |
egr isnt even hooked up. The wires are but the vac line isnt. Do you think that could cause the prob?
1990 5.0 LX Notch
I had the same issue. Come to find out I had a bad ground from the block. Also I reinstalled the salt and pepper shaker plugs. Now it idles about 850 after it warms up.
1990 mustang gt
n/a
Check the IAC and it's wiring you could have a short somewhere that is causing the IAC to be commanded open more than it should be. start at the IAC and test the wiring all the way to the computer.
Threads Similar to: Strange Idle
| Aftermarket TB/Plenum hanging idle/low idle issues! | Novanutcase | 99-04 | 12 | August 13th, 2008 11:24 AM |
| Very Strange | JASonic | The Clubhouse | 7 | December 29th, 2007 10:45 AM |
| Something Strange | rk_2000_Z/28 | Feedback Forum | 22 | November 21st, 2007 11:51 AM |
| Idle Problems Code 1506, Idle Overspeed Error | jagstang96 | 96-98 | 3 | August 29th, 2006 04:11 AM |
| Strange Idle | Stan27 | 99-04 | 29 | April 22nd, 2006 11:17 PM |
