Questions about an '88 - Page 3
LinkBack (1) Thread Tools
Old November 6th, 2008, 08:19 AM   #41
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Originally Posted by stage3_rx7 View Post
hmm. I'll take that into consideration. Drive it check those things out. No offence, but with the v8 suggestion. Rotarys are far far superior than the piston engine. The interior is clean. I got A painter. Other than that I'll put an agressive cam heads and intake manifold and see what it'll do but if it's beat to shit I won't even think about it. Thanks for the output and keep it going.
Yes the design is more superior in theory but they have yet to make a rotary engine big enough that makes any kind of impressive horsepower. So as far as production engines goes, the LS1 that was suggested is superior to the production rotatary engine.
Old November 6th, 2008, 01:27 PM   #42
nolife's Avatar
91GT, 88GT, 02GT
I had a 79 RX-7. It may be a nice design on paper but for a 1.0 liter or what ever it was, it burned a hell of a lot of oil and only got about 15 MPG even though the car was relatively small and light. I'm sure the design is a lot better now.
Old November 6th, 2008, 01:47 PM   #43
e3sean's Avatar
1988 lx
9.68@142
they do use a butt load of fuel. but thats cause its spinning at 12000 rpm's imagine if a v8 spun that fast how much gas it would use.
<font size=4><b>MILITARY CREW
Old November 6th, 2008, 02:49 PM   #44
78mach1's Avatar
78mach1 is on a distinguished road
Send a message via MSN to 78mach1
Originally Posted by e3sean View Post
rotery engines have their problems too.. you can easily blow the apex seal and then its less of a hassel just to put a whole new motor in it then it is to fix it.
and it will never have one thing TORQUE
but i am all about new and differnt things why dont you buy a miata and put that rotery engine in it with the 7lbs of boost.
exactly, in my opinion a rotary engine is a good design but they lack the ability to make torque because there is no direct force upon the rotation assembly, instead they are spinning a puck. they have extreme rpm ranges, which allows them to make up for not being able to produce torque. but the extreme rpms make efficiency hard to get out of a rotary engine.
Old November 6th, 2008, 03:30 PM   #45
stage3_rx7 is on a distinguished road
yes they don't make torque. They use so much gas and burn oil because those are used as lubricants for the apex seals. And with apex seals just got to upgrade them and then you will have a reliable motor. Mazda is working with new materials for apex seals but for now carbon is the best. They just don't put think enought ones on the rx8 or any rotory motor to make safe power. Yes they have flaws but what motor doesn't?
Old November 6th, 2008, 04:02 PM   #46
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
If a V8 spun 12,000 rpm and had heads to support that kind of RPM it would make a shit ton of horsepower. A smile would be on everybody's face.
Old November 7th, 2008, 11:33 PM   #47
Aussie v8's rev pretty rediculas. You should check it out. Wanna say it's at least 10k rpms.
Old November 7th, 2008, 11:47 PM   #48
mustangsoldier's Avatar
1993 Mustang
we'll find out when i come home from iraq.
mustangsoldier will become famous soon enough
before i say this keep in mind i have respect for rotaries so im not "just another muscle head" but if the rotary is God of engines and is superior why do so many rx7 owner swap the ls1 into them
shut up before i punch you in the throat
Old November 8th, 2008, 09:27 AM   #49
many people don't understand how the motor works. So they swap. But the majority buy them with blown motors and just drop a v8 in. Actually the most popular motor I see in them is a chevy 350.
Old November 8th, 2008, 02:36 PM   #50
Hunt_chevs's Avatar
2002 Gt
Not Slow
Originally Posted by 93mustank View Post
Keep the rx7....dont ruin a 5.0 with drifting antics
+1
Old November 8th, 2008, 02:42 PM   #51
78mach1's Avatar
same reason they swap ls1`s into fox bodies and 240/280z`s......and probably just to be a little different.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/96142-questions-about-88-a.html
Questions about an '88 This thread Refback November 4th, 2008 09:32 PM
Threads Similar to: Questions about an '88
i have 2 questions 5.0guy 5.0 Mustangs 17 July 17th, 2008 12:11 AM
A few questions... AMR91 V6 Mustangs 41 June 3rd, 2008 06:12 PM
2 questions 2000roush 99-04 2 March 21st, 2008 10:18 PM
Questions Questions Questions Youngin V6 Mustangs 0 October 23rd, 2007 03:56 AM
A few questions ericsc 2.3 Mustangs 14 October 22nd, 2007 10:41 AM
