Any of this sound good?
Old November 4th, 2008, 10:10 PM   #1
blakehunter316's Avatar
1989 Mustang GT
14.01 @ 103..... :(
blakehunter316 is on a distinguished road
I'm lookin at doin some stuff under the hood to make it look cleaner and gain a bit of power now does anyone think it would be worth it to get a polished cobra intake, tb, and new mass air. and some polished valve covers. is there any other suggestions ? will a new up/lwr intake and tb and mass air make any difference ? suggestions im just in a bine wat to do its a daily driver and my buddy just got a zex wet kit lol its sweet but i got 150,00 on it but u would never know ... just want to keep it n/a but then there is that supercharger idea...... got about 1300 and my other mods are in my sig. keep in mind its a daily driver.
vortech s-trim off road h pipe super 40's steeda tri-ax c.a.i. 3.73s subframe cnntrs 255er
Old November 4th, 2008, 10:12 PM   #2
mustangsoldier's Avatar
1993 Mustang
we'll find out when i come home from iraq.
mustangsoldier will become famous soon enough
gt40p heads, explorer intake, headers, cam. what kind of tires do you have?
shut up before i punch you in the throat
Old November 4th, 2008, 10:19 PM   #3
1989 Mustang GT
14.01 @ 103..... :(
i really dont wanna go with a cammed set up till i can get a second car. ....
Old November 4th, 2008, 10:28 PM   #4
1989 Mustang GT
14.01 @ 103..... :(
255/40/r17s good dry traction crap in rain
Old November 4th, 2008, 10:59 PM   #5
1993 Mustang
what brand and type of tire? some good drag radials would be good. also look at adding some suspension ie upper/lower control arms.
Old November 4th, 2008, 11:34 PM   #6
Makes perfect sense.........
PeteAndersonRacing.com
Old November 5th, 2008, 07:14 AM   #7
91cobra5.0's Avatar
98 Cobra
i agree if your going to spend ne money on the car at all u might as well spend it making good power, ive seen 5.0's with higher miles on them and a lot more power than stock and they hold up good. but any ways id go with a polished gt-40 intake (same thing as a cobra but cheaper) some gt-40 heads and a cam, that would probly put u at around 225 hp all motor and cost around 500 MAYBE
Old November 5th, 2008, 07:44 AM   #8
1989 Mustang GT
14.01 @ 103..... :(
Ur being serious? I was just thinkin about doing polished upper lower tb and something else would I see a power gain from that? I thought I woul make alot more than 225 w heads and intake .......
Old November 5th, 2008, 11:11 AM   #9
ryans88gt's Avatar
polished cobra intake is a cheap knockoff and not a real ford product. Lots of problems with oil consumption through the PCV with those intakes.
Old November 5th, 2008, 11:13 AM   #10
91 LX
13.7@101
that's good to know
Old November 5th, 2008, 11:22 AM   #11
ryans88gt's Avatar
It is fixable though if you get the full size ford baffle and put it under the lower intake. Or you can get a oil separator and run it inline with the PCV.
Old November 5th, 2008, 11:30 AM   #12
No...not serious
Old November 5th, 2008, 12:28 PM   #13
The biggest restriction on these motors it the stock heads... if you want to make any power those heads have to get worked big time or swapped. The gt40 heads are cheap and a decent improvement over the e7's but won't give you 45rwhp like the higher end heads plus you don't have all the supporting mods to get the most out of a head swap. Remember a 93 cobra which came with the cobra intake, cobra cam, 1.7 rr's, 24lb injectors, cobra computer, 70mm meter, 65mm tb, ud water pump pulley and gt40 iron heads didn't make 300 to the wheels.
The stock cam has been proven to make great power and on a street only daily driver why would you want to raise the power band higher? i'd say stick with the stock cam there have been people in the 11s I believe on corral.net running the stock cam.
Stock mass air flow sensor is something like 55 or 58mm where as any aftermarket meter is going to be anywhere from 70mm to 90 plus.. the stock throttle body is either 55 or 58 and a mild to stockish car doesn't need more then a 65mm and yes the stock upper/lower sucks balls but replacing these three things aren't going to net you tons of rear wheel horsepower but coupled with a head swap you will.
Just some things to think about... you could do the meter, tb and intake swap now and save and do a head/cam package later after you figure out what power level and rpm range you want the car to hit
Old November 5th, 2008, 05:23 PM   #14
1989 Mustang GT
14.01 @ 103..... :(
No...not serious
ok im 17 and short on cash cut me a brerak its all i got to drive. flyin ryan: i was thinkin about doin that acutally then gettin a set of heads when i find something to drive.
Old November 5th, 2008, 05:31 PM   #15
gt40 heads, a nice little cam like a TFS stage 1, gt40 tubular or explorer intake, 24# injectors, matching MAF, and 65-70mm TB can all be had for well under 1300.
It's a nice pickup from stock. I haven't dynoed my combo but I have all those parts with a B303 cam.
However, if anytime in the near future you are going to go bigger, i would suggest saving the $1300 toward that project.
[SIGPIC][/SIGPIC]
[B][U]MM Sapper Squad[/U][/B]
Old November 5th, 2008, 06:14 PM   #16
1993 Mustang
well said tony
Old November 5th, 2008, 06:20 PM   #17
1989 Mustang GT
14.01 @ 103..... :(
[QUOTE=Tony_90fox;1572865]gt40 heads, a nice little cam like a TFS stage 1, gt40 tubular or explorer intake, 24# injectors, matching MAF, and 65-70mm TB can all be had for well under 1300.
However, if anytime in the near future you are going to go bigger, i would suggest saving the $1300 toward that project.[/QUOTE
am i lookin at about 50 horses with that ? .... let me know if u dyno it soon i would like to see ur #'s !
Old November 5th, 2008, 07:51 PM   #18
I'd say 50-65 most likely... I have an AOD so my HP gains were lower, probably closer to 50. I trimmed about 1.5 seconds off my ET though.
It's a good combo for daily driving and running 12-13 seconds at the track...
[SIGPIC][/SIGPIC]
Threads Similar to: Any of this sound good?
O/R X and JBAs sound surpsingly good gragra73 2005 - 2010 2 October 18th, 2008 09:54 PM
sound like a good deal? HBK_2007 96-98 10 August 25th, 2008 09:32 PM
suspension kit sound good 01dutchGT Classic Mustangs 3 June 10th, 2008 06:02 AM
Is it possible to make a v6 actually sound good? mustangmanic The Clubhouse 42 April 15th, 2008 09:15 PM
would this sound good? DeathScythe95 V6 Mustangs 17 August 4th, 2007 01:49 AM
