![]() iTrader: 1 reviews
Which Master Cyl.
I am getting ready to switch my fox over to 5 lug with 95 spindles and 13 inch cobra brakes front and rear. I have read the brake sticky, and would like to hear from the people who have done this swap. Is there a way to switch to front and rear disc and not have to use an after market proportioning valve. What is the best master cyl to use on the swap. Thanks Mark
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
84-86 Svo Master
Cool thanks for the info!!! Do I need a different porportioning valve for rear disc???
I think we just pulled it out and it worked fine,
maybe I am full of shit I really can't remember, but that does ring a bell |
I'm pretty sure you have to swap out the proportioning valve on a fox disc swap. It's not expensive, and easy to do.
I had a MC from a 95 Mustang, which I found made the pedal really stiff, then I switched to a 93 Cobra booster and MC - softer pedal feel, and increased responsiveness IMO.
Bart 93 Black on Black GT Kenne Bell S/C ![]() GIVE 'ER! |
I would get an adjustable proportion valve
EVERYONE IS ENTITLED TO MY OPINION:cool: 6'ers are for kids 1965 chevelle SS 421 sbc 6 speed, 3.90 gears,alum d-shaft, brodix heads,roller cam,925 AED carb...grocery getter*[COLOR="Red"]RIP[/COLOR]* |
#7 | |
some one want to pm me a complete list of all parts and the years off of what car is needed for a good 5 lug conversion... disc's all the way around!!!!!! plz and thank you
2000 V6 Performance Red @ Cardomain Was fun but a waste... 1987 LX Hatch | Soon to be a 600hp monster |
Master
Cool! Thanks for the info. I will get a 93 cobra master, booster, and proportining valve.
My next question is I have drum brakes now, and am going to rear disc. Do I need a whole new rearend, or can I get away with brackets???? Any suggestions??? Thanks Mark |
WIth the SVO mastercylinder, you don't need anything else. That is the easy way to do it.
For the rear disk all you need is the calipers, brakets, rotors, pads, and you will have to get some brake line adapters. You do not need a new rear. The axles were longer on 93 cobras and SN95 cars, but you can get caliper brakets made specifically for a fox swap so that you can use the stock length axles.
master
ryan88gt-
So I can keep my stock booster with the 84-86 svo master??? I am switching to 5 lug axels, can I buy 93 cobra axels and use regular brackets for the disc??? Thanks Mark |
yes about the booster, I had it on my last car
you can use SN95 axles and brakes, cobras were 4 lug.
isn't the sn95 axles longer?
Get some Fox length 5 lug axle shafts and the brackets off the Internet. SN95 shafts are long, and if you run a big fat tire in the back, your outer fenders are going to rub the tire.
Since we're on this topic: Anybody who has cut their e-brake spring and welded it a la SN95 style - how do you keep pressure on the fucking thing so your e-brake light doesn't keep flashing on and off since the original spring gets cut out??
you will also need to change the emergency brake cables
THe SN95 axles are 0.4 inches longer. Your wheels will not rub unless they are very close to rubbing already. And since you are buying wheels anyway (going 4 lug to 5 lug) if you get the correct backspace there is no reason why everything wouldn't fit.
The axles need to be longer to run the SN95 brakes or you need expensive brackets.
Close - they're .75 inches longer per axle shaft.
IMO a lot of cars look funny because people don't buy the right rims for the back. If you change to SN95 spindles in the front, and use SN95 shafts, for the car to look right, you really need to buy front and rear rims with different offsets, or the car looks weird.
Threads Similar to: Which Master Cyl.
| I AM the master chief! | Dansby | The Clubhouse | 9 | October 5th, 2008 11:58 PM |
| Flow Master rattle? | xXsmokinaceXx | V6 Mustangs | 10 | January 8th, 2008 09:09 PM |
| Master Cylinder Reservoir | WAR-PARTY | 99-04 | 0 | October 10th, 2007 07:04 PM |
| 4 cyl maf sensor or 8 cyl? | Darrellx14 | 5.0 Mustangs | 12 | January 11th, 2007 10:15 AM |
| Looking for someone who has actually done a 4 cyl-8 cyl swap | OTreborO | 5.0 Mustangs | 0 | August 17th, 2006 11:16 AM |
