Engine swap question
Old November 5th, 2008, 01:16 PM   #1
hopper is on a distinguished road
I have an 84 5.0 carbed with a non HO engine.
I want to throw a 88 engine that i have around the garage into the car. Will my intake and carb bolt right onto the heads of the 88?
DO I need to change the heads to accept the carb and intake?
Thanks for any help
Cheers
Old November 5th, 2008, 01:35 PM   #2
Your good to go....just change the timing cover...and dont forget to change the distributor gear to steel .....
PeteAndersonRacing.com
Old November 5th, 2008, 02:39 PM   #3
91 LX
13.7@101
yeah you're good. just out of curiosity what intake and carb are you going with?
Old November 5th, 2008, 03:11 PM   #4
I have a holley 650 on top of a weiland intake. Nothing crazy
Why can i not use the same distributor?
Old November 5th, 2008, 03:35 PM   #5
Because of the roller cam.....steel gear
Old November 6th, 2008, 08:24 AM   #6
can I just change the gear on the bottum or do I have to change the whole distributor. Will the distributor that is coming on the 88 fit into the carbed intake?
Old November 6th, 2008, 11:03 AM   #7
Smirnoff's Avatar
1982 GT t-top
no proof of purchase
Smirnoff is on a distinguished road
just change the gear on the bottom, on my 82 i had to change the gear on the bottom because the connections for the electrical were different and it had a vaccum advance.
Old November 7th, 2008, 09:19 AM   #8
that is what i figured. but they should all have a vaccum advance.
Old November 7th, 2008, 10:44 AM   #9
jcashmoney018 is on a distinguished road
yea they should it is better to just change the bottom gear. it will save u time and money
Old November 7th, 2008, 04:23 PM   #10
cool appreciate it
Threads Similar to: Engine swap question
Which one is easier??a rear end swap or engine swap? Bies08 V6 Mustangs 42 May 11th, 2010 04:33 PM
Engine Swap Question! 02MustangV6e9 5.0 Mustangs 3 September 24th, 2008 02:16 AM
Engine swap question energiesource 99-04 11 September 19th, 2008 06:54 PM
Engine harness swap question. Superarnie 94-95 5 August 6th, 2008 10:10 PM
Another Dumb Engine Swap Question OcOnnor220 99-04 8 July 31st, 2007 02:00 PM
