timing ?
iv got a 347 at 9.5:1 compression with dart victor sr. cast iron heads trick flow stage 2 cam edelbrock rpm air gap intake with a blow-through demon 650 carb and a paxton sn92.
i need to know what the timing should be at idle? right now its at 14 deg. |
1990 LX hatch
it should be set just below the point of detonation. Depending on fuel that could be anywhere from 12-18*
shit I'd be @ 10..that's a small carb depending on psi...should be a 750 atleast
EVERYONE IS ENTITLED TO MY OPINION:cool: 6'ers are for kids 1965 chevelle SS 421 sbc 6 speed, 3.90 gears,alum d-shaft, brodix heads,roller cam,925 AED carb...grocery getter*[COLOR="Red"]RIP[/COLOR]* |
#4 | |
The timing you will have to play with to see what the engine likes. Timing at idle isn't the important part, its the total timing under boost that is critical.
Threads Similar to: timing ?
| timing | Rustbelt | 5.0 Mustangs | 2 | August 6th, 2008 01:11 PM |
| timing? | riddlee josh | V6 Mustangs | 31 | February 9th, 2008 01:00 PM |
| Timing Help Me | skid6 | 5.0 Mustangs | 3 | November 19th, 2007 09:42 AM |
| timing | punkafi888 | V6 Mustangs | 13 | March 29th, 2007 01:01 AM |
| need help on my timing????? | tag team | 5.0 Mustangs | 3 | March 26th, 2007 12:04 AM |
