Emergency brake light
Old November 6th, 2008, 02:16 AM   #1
90 Lxer's Avatar
2004 Mach 1
90 Lxer is on a distinguished road
A few weeks back when I was driving I heard a loud pop from the rear end of my car then the emergency brake light came on then about 15 seconds later the light went off.
For the next couple of days the light would randomly come on then go off again so I took it a couple of places and had everything checked out and they told everything was fine but when I drive over 3500 rpm and let off the gas it comes back on again.
Anyone know what could be causing this?
Old November 6th, 2008, 03:04 AM   #2
00SoSlow's Avatar
00SoSlow is on a distinguished road
Send a message via AIM to 00SoSlow
make sure your resevoir for brake fluid is full... if its low, the float will trigger the light causin it to come on under acceleration the fluid goes to the back and the float falls forward!!! try that and let me know how that goes... u probably just backfired, causin a pop from the rearend
Try fillin it and then do what u do when the light goes on and let me know
i had a similar prob
2000 V6 Performance Red @ Cardomain Was fun but a waste...
1987 LX Hatch | Soon to be a 600hp monster
Old November 6th, 2008, 03:06 AM   #3
00SoSlow's Avatar
i have a slow leak some where, and im not worrying about it since its all gettin new SS lines this winter hopefully. comes on every 3 weeks or so... just fill up and good to go till it gets low again
Old November 6th, 2008, 01:23 PM   #4
nolife's Avatar
91GT, 88GT, 02GT
Make sure you actually have a leak. As the pads and shoes wear down, more fluid stays in the wheel cylinders and the pistons and less in the reservoir. New pads and shoes can bring the level back up again. I know you said you are changing the lines but a leak could be from from a wheel cylinder seal or the piston seal, not the actual lines.
Old November 6th, 2008, 01:57 PM   #5
00SoSlow's Avatar
im thinkin my brake booster is leakin... all wet under neath it...
Old November 7th, 2008, 01:20 AM   #6
90 Lxer's Avatar
2004 Mach 1
I checked the fluid level it was a little low so i went ahead and put some in then tryed it and no light. Thank you for your help.
Old November 7th, 2008, 02:40 AM   #7
00SoSlow's Avatar
sure thing... just keep checkin the level... it comes back on i suggest checkin the booster, mine went and the seals are leakin..
Threads Similar to: Emergency brake light
Emergency Brake WAR-PARTY The Clubhouse 4 December 16th, 2007 12:07 PM
Emergency Brake Light and Backup lights-help!! Bullitt8323 Audio/Video 0 November 16th, 2007 01:44 AM
question about emergency brake light Paulnhbtx 99-04 2 October 24th, 2007 12:38 PM
Emergency!!!!..............................Brake flames_blue V6 Mustangs 15 April 12th, 2007 08:28 PM
Annoying emergency brake light HedCR 99-04 10 February 9th, 2007 07:04 PM
