Cobra Running Horrible.....need help
LinkBack (1) Thread Tools
Old November 6th, 2008, 08:40 PM   1 links from elsewhere to this Post. Click to view. #1
1995svtcobra's Avatar
95 SVT Cobra
1995svtcobra is on a distinguished road
Ok guys i need some help. i have a 95 cobra, owned it for 3 years never had much problems with it, great car. its started running horrible a couple weeks ago. i limped it home, it had a lot of vibrations throughout the drive train that I could feel while driving. it was hard to keep running extremely rough at idle and when giving it gas. since having it at home i have changed the plugs, pretty sure the spark plug wires are good, changed the distributor cap, rotor, and cleaned the air filter. No change still running like crap. The motor has a vibration or a shake that you can see while it's running. It will idle but very roughly. today i tried to do a vacuum test to see if i had a leak. I used one of the lines going to the egr valve o get my gauge reading. not sure if that is ok?? tried some of the lines around the throttle body but i could not get a reading. at the egr tube i'm getting about 10 in. Hg. at idle. when you give it gas it will increase to 12-14 in. Hg. from the book that came with the gauge it seems like it could be a number of things. maybe restricted exhaust flow, clogged cats maybe?? any help would be great. i first wondering if you have any ideas. if i can get a accurate reading from the egr vacuum line, or if not which one to use??? do you just unplug the line and plug it into the gauge or do you have to do a "T" connection that way it is still hooked up? never done vacuum testing before so i'm not sure. thanks for any help
Old November 7th, 2008, 01:32 AM   #2
Nice 5.0's Avatar
1993
12.9 @ 105
Nice 5.0 is on a distinguished road
Check for a vacuum leak by spraying around the intake with carb cleaner. You may need to do a compression check. Also how do you know the wires are good. I would have changed plugs and wires first, before everything else. They could be bad. You have to go through a process of elimination.
Old November 7th, 2008, 01:55 AM   #3
1992 Lx
11.39@119.24
pull off the h pipe and try and start it
Old November 7th, 2008, 07:18 AM   #4
95 SVT Cobra
I doo\n't think it's the wires because they were replaced a few years ago with a high quality 8mm set. I guess they could have already gone bad, though. Nice 5.0 what will happen if you spray the carb cleaner around the intake? This will tell you if you have a vacuum leak? Let me know never done this before. thanks guys
Old November 7th, 2008, 02:58 PM   #5
Mlx50man's Avatar
90 Mustang lx Boss 347
Mlx50man is on a distinguished road
Send a message via AIM to Mlx50man Send a message via MSN to Mlx50man
+1 if you have the stock h-pipe with cats, your cats might be plugged.
Old November 7th, 2008, 09:16 PM   #6
vfast will become famous soon enough
does it heat up?
the vibration check the harmonic balancer
EVERYONE IS ENTITLED TO MY OPINION:cool:
6'ers are for kids
1965 chevelle SS 421 sbc 6 speed, 3.90 gears,alum d-shaft, brodix heads,roller cam,925 AED carb...grocery getter*[COLOR="Red"]RIP[/COLOR]*
Old November 9th, 2008, 03:28 AM   #7
americanmuscle90's Avatar
1990 mustang gt
n/a
americanmuscle90 is on a distinguished road
You can check the wires w/ a multimeter there should not be more than 10000 ohms of resistance per foot of wire.
First do a good visual inspection checking for obvious problems i.e. fuel and vacuum leaks, and bad connections. Check all of your fluids. Make sure they are in servicable condition. You may find coolant in your oil, you never know. Alot of problems come from overheating, so check the coolant. Test for spark at each cylinder using a spark tester. Check fuel pressure and ensure it is within specs. If you have the ability to retrieve DTCs they can be very helpful. Perform a compression test to check the mechanical soundness of the engine. If a cylinder has low pressure perform a wet compression test to determine if you have bad rings. If the pressure comes up during the wet compression test the rings are bad. If it doesn't come up you have bad valves or blown head gasket.
You have owned the car for 3 years it is not like you just bought it and hve to give it a complete tune up. I would not have rplaced a single part until I found the problem. You are wasting money that could be used for mods instead. DO NOT throw parts at a problem. Use troubleshooting fundamentals to solve a problem. You know an engine needs fuel, spark, air, and compression to operate. You also know it needs to be cooled and have a means of letting the exhaust escape. Start with the process I laid out and I know you will find the problem w/o spend alot of money.
Now if you don't find the problem you need to start testing the sensors, mostly the input sensors to the PCM like the ECT, MAF, IAT/ACT, O2S, MAP, ect. Keep us updated. If you need help you can contact me.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/96463-cobra-running-horrible-need-help.html
Cobra Running Horrible.....need help This thread Refback November 7th, 2008 08:02 AM
Threads Similar to: Cobra Running Horrible.....need help
Horrible Rattle... joeice14 2005 - 2010 3 July 22nd, 2008 05:37 PM
Horrible Day joeice14 2005 - 2010 29 December 8th, 2007 03:26 AM
Horrible Crash Stangzilla Videos 3 April 9th, 2007 02:56 AM
This is horrible Cricket The Clubhouse 46 April 3rd, 2007 07:18 PM
I have horrible luck........ DSEZ The Clubhouse 30 February 17th, 2007 03:07 PM
