motor block ?'s
i am gonna be puttin nitrous on my car this winter so i was just wondering what is the most the stock block with all forged internal could handle? what would be the biggest shott that i could run safely? would a 150 shott work?
thanks 4 your time
![]() FORD = FOUND ON ROAD DOMINATING www.myspace.com/stangdevin |
1986 lx notch
9.98 @ 135
150 easily/reliably ......... 200 ehhhh ......... for a while
![]() " Spending money I don't have.... on things I don't need .... to impress people I don't know " . |
Ok nice thats nice to hear i guess thats what i am gonna do this winter!!!! do u have any suggestion on what i should buy and do? like what kind of pistons should i get and stuff like that and proper stuff to run nitrous safely?
thanks 4 ur time
RIP Justincredible! God Speed
Do you already have a rotating assembly?
9.91@ 134mph 1/4 - 6.17@ 109mph 1/8th - 1.33 60' - Stock ECU & Stock Suspension......and getting faster . BIVENS RACE CARS FTMFW!!! |
1987 ford mustang gt
well see when shes done
why is it always the same damn questions over and over.. Yes a 150 will be fine.. i would recommend some forged pistons though.
2004 tahoe z71 Daily 2004 BBM Gto ls1 6 speed 57,000 miles 1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600 |
1986 lx notch
9.98 @ 135
you dont' need to do anything to your motor to run a 150 shot except to run good gas and retard the timing according to the instructions in the nitrous kit. i do suggest a fuel pump upgrade tho, it's cheap insurance @ 100 bucks also not mandatory but i'd get a colder set of plugs for a little bit of added insurance ( autolite 24s )
Would there be any tuning necessary? Or could you just run colder plugs, fuel upgrade and a 150(wet or dry) shot and your good?
302, Cobra upper and Lower Intake,UDP's,BBK Shorties with Flow Dumps, SMog Delete,CAI, 70mm TB, K&N Filter, Timing 14 degrees, Lowered 1.5, 3.73's, Nitto Dr's. "Its not that there is ever too much Horsepower, but not enough traction."
take out 6 degrees of timing (2degrees per 50hp of nitrous=6 degrees for 150shot)get a walbro 255lph intank fuel pump for extra insurance and 1-2 step colder sparkplugs.now if you still have the factory 1993 pistons just hope they stay together
also whats a motor block? i didnt know 5.0s ran on electricity maybe it was a secret option when you bought the car.motors are electric.
2002 Gt
Not Slow
![]() iTrader: 1 reviews
a bone stock 302 can handle upwards of a 150 shot no probs
2k2 Gt Eibach pro kit, bbk cold air, exhaust, 4.10s, 6k hid's |
I ran a 200 shot on my 170,000 mile 5.0 with a TFS top end kit and had no issues for well over a year, going to the track every weekend.
Even better....I sold that short block to a college kid who put it in a daily driver that he built on the cheap...and to the best of my knowledge...it's still going. The key to longevity with nitrous is to have a good tune, use good fuel, a good fuel pump, dont get greedy with the timing, and check your plugs often.
#12 | |
On the 200 shot....I would run my fuel tank close to empty and drop a few gallons of 110 octane race fuel in the tank once I got to the track.
On a 150 shot...Id just be sure to run my tank down and then top it off with a good name brand 93 octane (Cheveron, BP, or Shell). I also preferred to buy my pump gas from a newly built gas station to avoid any debris and water that is common in old gas station holding tanks. Some might say its overkill....but Id rather spend a little on good fuel and not have to spend alot on a new short block.
it's the rod bolts I would be worried about
EVERYONE IS ENTITLED TO MY OPINION:cool: 6'ers are for kids 1965 chevelle SS 421 sbc 6 speed, 3.90 gears,alum d-shaft, brodix heads,roller cam,925 AED carb...grocery getter*[COLOR="Red"]RIP[/COLOR]* |
Typically....the block will give up long before the rod bolts.
Atomized
Dude I had 188,000 mile on my stock motor with over 20 bottle of nitrous with probably 10 of those at a 200 shot. I had zero problems. My motor did give but I was crusing down the freeway when it did. So i did a ghetto build for now hci, and a stock forged rotating assembly all together with new rings bearing gasket's i spent like 300 bucks on the rebuild. So far I've put 8 bottles of nitrous with a 200 shot on the re ringed motor with zero issues.
ok i changed my mind i am gonna get a supercharger!!!! what is the max boost that i can run on a stock block? what should i have for compression to run 10 to 15 pounds of boost?
Threads Similar to: motor block ?'s
| new motor/short block | 99 gt | 99-04 | 13 | May 7th, 2008 09:10 PM |
| want to do a motor swap or new long block | thecloneranger | 99-04 | 4 | April 16th, 2007 03:25 PM |
