1986 LX
none yet
3g alternator upgrade
Just finished the 3g upgrade. Seem to work better but my fans still seem to pull on it pretty hard at itle. didn't get the chance to leave the driveway due to current headlight issues. will check to see tomorrow. I also heat wrapped the starter. I still think I need a new one. I let the car heat up to around 160 and shut it off then try to start it, it hesitates then spins and starts the car. It is sitting a good 4 inches from my down pipe I just think its going out because of the general heat in the bay.
so one question I have, on the starters in the late foxes, not sure exactly what years but since they started with the solenoid on the body rather than on the side wall, are they rated for higher torque than the older ones? I mean other than high torque starters obviously. And I dont imagine for any reason that I should need a high torque starter since I run a low compression (about 9 to 1) boosted set up. but if anyone thinks different Im open to suggestions. thanks |
What do you have for a fan set up? If you have one of those junk Taurus or Mark VIII fans, they will bog down a nuclear powerplant because they draw so much power so it really doesn't matter what alternator you use.
1992 is when they started with the high torque starters in Mustangs. I've had a lot of problems with the stock Mustang starters. I put a Powermaster in everything I own now. I haven't had a failure in 8 years of using them.
94 GT
i had the same problem with my starter that you are having, bought a new one and havent had any issues with it. i also had long tubes running right on top of it and drove it everyday and never had a heat issue with no wrap.
and for the fan thing, are u running 2 or 1 fan set up? if a 2 fan then wire each fan into its own switch so that you can run only 1 fan at a time, i know with my car i find my self rarely even using my fans due to the fact that my engine hardly sits in the middle of the guage and i have all factor cooling equip (minus the ac condenser)
94 GT - Deep Forest Green Off road X, flowmaster single chambers, typhoon intake, hurst short throw, CAI, eibach sportlines, 315s, foxbody short block ![]() |
most of the aftermarket high torque starters are smaller anyway other than being stronger.usually alternators dont cut in until above idle so thats why the fan puts a lot of stress on the charging system. those mark fans draw around 80 amps when they turn on
1986 LX
none yet
actually I run a probe fan set up which is dual. I have it all wired through a single switch and 30amp relay. one pushes and one pulls. I need both fans because when I actually do drive the car (rarely, sadly), it gets pretty hot since I run non intercooled and fairly high boost most of the time. I used to have cooling problems when I ran a single flex a lite electric fan so maybe it was too hot then and fried my starter. I need a new one no matter which way I go. Im still thinking exhaust wrap is on the to do list though just for velocity purposes, and then the cooler temps will just be an added plus.
1986 LX
none yet
#7 | |
I don't know for sure.
#9 | |
1990 LX hatch
#10 | |
1986 LX
none yet
I just found a fan on ebay that looks pretty much identical to my old one. Im not sure if this is the same as you are talking about though |
1986 LX
none yet
so I just took the car around the block. started to bog. died. my dumb ass ran it out of gas. had the wife bring me some and got going again. made a loop and my feet got covered with smoke. pulled over to find out that my wiring melted from my power block to my relay for my fans. Im curious if maybe the output of the new alternator made it do that. any thoughts?
1986 LX
none yet
found the smoking problem. it wasn't the alternator. It was a hot lead that had managed to get stripped back a little and ground out. no big deal
Threads Similar to: 3g alternator upgrade
| Alternator Goin Out... Time For 3G Conversion? Info On Good Upgrade | Iwannagofast | 5.0 Mustangs | 96 | December 11th, 2007 12:16 AM |
| 3G alternator.... | Casper98GT | 5.0 Mustangs | 11 | October 2nd, 2007 06:16 PM |
| best alternator upgrade | redponygt | 99-04 | 1 | May 4th, 2007 11:38 AM |
| 1988 5.0 alternator upgrade | QQQQ | 5.0 Mustangs | 5 | March 3rd, 2007 01:23 PM |
| alternator | terribleonexx88 | 5.0 Mustangs | 16 | December 1st, 2006 09:39 PM |
