Aother Problem
Old November 9th, 2008, 02:10 PM   #1
1994, mustang gt
N/A
izze01 is on a distinguished road
Send a message via AIM to izze01
Aother Problem
Went to start my car this morning and it just cranked and didnt start, I going to pull a spark plug and see if it will spark to check the ignitor box, also thought it could be the distributor but how would I check that? Also could it maybe be the fuel filter is clogged, I smelled gas at the back of the car and I can hear the fule pump kick in, I havent changed the filter in awhile and thought maybe that could be it? Any thoughts thatnks?
Old November 9th, 2008, 03:50 PM   #2
1994, mustang gt
N/A
anyone?
Old November 10th, 2008, 08:01 PM   #3
americanmuscle90's Avatar
1990 mustang gt
n/a
americanmuscle90 is on a distinguished road
You should check for spark but don't use the plug, use a spark plug tester. If you get a spark you know the distributor is good. Also, check your fuel pressure at the rail. If that is good you don't need to change the filter. Those are two places to start, good luck.
Old November 10th, 2008, 09:17 PM   #4
Always rule out spark first.....Starting fluid first.... If it wants to run on that then its a fuel issue...if not ignition
PeteAndersonRacing.com
Threads Similar to: Aother Problem
Another Problem... Chevyeater351@yahoo.com 5.0 Mustangs 15 September 11th, 2008 09:25 AM
O Jesus! Problem After Problem! mustangmanic 99-04 94 March 28th, 2008 03:36 PM
umm have a weird problem? idle problem? blue03mach1 99-04 16 March 4th, 2008 12:03 PM
new problem smoke-em 99-04 4 May 24th, 2007 07:43 PM
Big Problem Or Little Problem? wraitherx 5.0 Mustangs 17 November 21st, 2006 08:45 PM
