Why am i burning through starter solenoids?
Old November 10th, 2008, 06:32 PM   #1
fateisajester's Avatar
1989 Ford Mustang
3 mins
fateisajester is on a distinguished road
Send a message via AIM to fateisajester
I Got my mustang about 4 months ago and since then i have gone through 3 starter solenoids, and im about to have to change it again. Im not getting crap solenoids either, im getting bosch. Its always the same... they work great at first and then after a few weeks, they start to act like the battery is dead. The starter turns extremely slow if it even turns at all. Other than that the solenoid just clicks. And if you try to start the car more than twice when its acting up, the fkn solenoid starts smoking. after it goes completely out, you can still hear it click but there is no juice getting to the other post, like the plunger has been burnt off. I have no idea why im burning through solenoids like this.
BTW, im not stupid. Im not engaging the solenoid too long. My car starts in 2 turns. Always.
Old November 10th, 2008, 06:39 PM   #2
uedlose's Avatar
89 Mustang
uedlose is on a distinguished road
maybe a starter gone bad putting to much amp load on the solenoid or bad cables, get the thing checked to see how many amps it is drawing when you are cranking it.
Old November 10th, 2008, 07:40 PM   #3
vfast will become famous soon enough
buy ford ones...check you wire to the starter,I'd replace it with a "0"gauge
EVERYONE IS ENTITLED TO MY OPINION:cool:
6'ers are for kids
1965 chevelle SS 421 sbc 6 speed, 3.90 gears,alum d-shaft, brodix heads,roller cam,925 AED carb...grocery getter*[COLOR="Red"]RIP[/COLOR]*
Old November 10th, 2008, 07:43 PM   #4
MMs Ford Racing Nut Swinger
1FUN4RD's Avatar
2007 MUSTANG GT
1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold
could be a weak ground or a bad starter
www.1fun4rd.blogspot.com
Old November 10th, 2008, 07:45 PM   #5
americanmuscle90's Avatar
1990 mustang gt
n/a
americanmuscle90 is on a distinguished road
I agree that your starter is probably drawing to much juice. You could have too much resistance in the wiring somewhere. Also, if your battery is bad it can cause the starter to draw extra more current to turn over.
Old November 10th, 2008, 11:52 PM   #6
1989 Ford Mustang
3 mins
Im not sure if its a 0 gauge but its about as big around as my first finger... and the original solenoid i burned up was a factory ford solenoid.
Can they test my starter to see how many amps its pulling without me taking it out?
Old November 11th, 2008, 12:13 AM   #7
91cobra5.0's Avatar
98 Cobra
buy a new starter from like autozone with the solenoid on the starter with a 1 year warrenty, check all of ur wires to make sure they are tight and no wires are burnt out. and make sure all the grounds are on clean metal and tight.
Old November 11th, 2008, 01:52 AM   #8
3521's Avatar
1988 Gt Cali car
3521 is on a distinguished road
I had a similar issue. I never replaced the solenoid though. I found my negetive cable had some corrosion where it bolts to the block, after I replaced it the car started great......... for the day. Then it acted like it had a dead battery again. I checked with a multimeter and it said it had 12v but it still wouldn't crank the car over. So I decided to put the battery on the charger and after the evening of charging the car starts great, it's been about a week now with no problems. Before my cables got really hot due to the corrosion, also with the corrosion it caused my battery to not charge properly.
Old November 11th, 2008, 08:31 PM   #9
looking to buy sn95 5.0
MaPolley07 is on a distinguished road
Why buy a 1 year warranty starter? The Valucraft with a 1yr warranty is junk, buy a Duralast with a lifetime warranty, only a few bucks more, and the last starter you'll ever have to pay for
I work there and wouldn't take anything Valucraft for free. Duralast parts are worth it for the warranty
Threads Similar to: Why am i burning through starter solenoids?
Starter solenoid clicks at the starter but wont start the car?? 95StangSVT 94-95 13 March 11th, 2010 10:22 PM
NX Stage 6 Solenoids MyGT General Tech 8 October 7th, 2008 02:54 PM
NX Stage 6 Solenoids MyGT 99-04 0 September 30th, 2008 04:42 PM
frying solenoids???? help onehot351 5.0 Mustangs 1 June 16th, 2008 11:32 AM
Fuel Problems Burning Rich / Burning Lean Steves LX 5.0 Mustangs 5 March 21st, 2007 09:46 PM
