Breather caps
Old November 11th, 2008, 02:30 AM   #1
Chris951's Avatar
1991 mustang 5.0
Chris951 is on a distinguished road
Breather caps
I've heard not to put one on an EFI car. But my old s10 blazer with a TBI 305 had one and it ran just fine. I have an older one from the blazer I want to put on my 5.0 for purely cosmetic reasons. Would this cause problems? I'm not worried about emissions because I don't have to pass smog in my county.
Here's what mine looks like
Wouldn't these cause more of a problem than one like mine? I would think mine would restrict the flow more than this one which i guess is better?
Let me know guys thanks.
Old November 11th, 2008, 07:14 AM   #2
The Razor's Edge
White Thunder's Avatar
you had a ford breathing cap on a blazer? i dont see any reasons not to....if they say it would be better to block the place your putting it just block it and then put the cap on.....for looks
founder of the FTN Club
Old November 11th, 2008, 09:49 AM   #3
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
If you are still running the stock PCV set up than you dont want to run an open breather as it will be sucking in unmetered air. If you are dead set on running that breather than do away with the PCV and run one breather on each cover.
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
Old November 11th, 2008, 02:31 PM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
+1
Old November 11th, 2008, 03:56 PM   #5
Chris951's Avatar
1991 mustang 5.0
No, I said it just looks like that one.
Threads Similar to: Breather caps
Air Breather Increase HP droppedbass87 General Tech 53 July 31st, 2011 07:32 PM
oil out of breather nasty92LX 5.0 Mustangs 1 August 14th, 2007 03:13 PM
Breather Cap Jorge 96-98 4 June 13th, 2007 03:34 PM
Air Breather WeCircleTheProblem V6 Mustangs 11 October 19th, 2006 10:12 PM
Connectors For Breather Hose slickfifty 2005 - 2010 3 September 24th, 2006 09:53 AM
