Help with valve springs upgrade - a problem
LinkBack (1) Thread Tools
Old November 11th, 2008, 06:58 PM   1 links from elsewhere to this Post. Click to view. #1
trumpet1 is on a distinguished road
Now you 5.0'ers don't get mad. I am posting this here because you probably know the answer, even though the question is about stock '68 302 heads.
I swapped in a mild lift cam upgrade, and was told to get new valve springs. Mustangs Unlimited recommended a Trick Flow upgrade kit. The kit wants 1.8" under the spring retainer to the spring seats. But the stock height is 1.66" and there is no way I can get close to 1.8" I think squeezing them to 1.66" defeats the purpose of the high lift cam?
Do I start over?
Thanks.
Old November 11th, 2008, 07:50 PM   #2
3521's Avatar
1988 Gt Cali car
3521 is on a distinguished road
Haven't looked into machine shops to have the seats cut?
Old November 11th, 2008, 08:01 PM   #3
Racinjason81 is on a distinguished road
you could get longer valves
Heres a real funny video
youtube.com/watch?v=ojB7KkaR03I
VTEC stands for Very Torqueless Economy Car
Honda stands for Hold On Not Done Accelerating
1991 LX 5.0 H/B(T-70 turbo coming soon)
Old November 11th, 2008, 08:14 PM   #4
JBIGBOOTSY's Avatar
1990 LX hatch
The easiest, and most cost effective answer.
Old November 14th, 2008, 12:19 AM   #5
Brian@PAR's Avatar
Brian@PAR is on a distinguished road
The only way for anyone to help you is for you to post the specs on your parts. We know the springs call for a 1.8 installed height (whether that is right or not is unknown) but we need to know what do the springs coil bind at and what is the lift of the cam. You are not going to cut the seats .140 so that is out but you can get offset locks and you may not need 1.8 IH. I just did springs on a set of 68 289 heads and it took over 300 bucks worth of springs, locks, retainers and shims to get them in right on an ecam.
This was using the stock valves which have the same installed height as the heads you have there.
PeteAndersonRacing
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/97088-help-valve-springs-upgrade-problem.html
Help with valve springs upgrade - a problem This thread Refback November 11th, 2008 08:38 PM
Threads Similar to: Help with valve springs upgrade - a problem
do i need new valve springs? 00mustang00 99-04 13 October 2nd, 2008 12:56 AM
valve springs flattusmaximus78 5.0 Mustangs 21 March 9th, 2008 09:28 PM
lookin for valve springs... Modern_Muscle 2005 - 2010 8 September 20th, 2007 07:02 PM
removing valve springs stangthang15 99-04 1 May 22nd, 2007 02:49 PM
Valve Springs Needed? metu107 2005 - 2010 1 November 30th, 2006 02:35 AM
