1990 Mustang GT
13.64 @ 101 MPH
Gear calculations
wondering if anybody has this formula. or a link they can get to quick for me to use. im gonna order some gears for the 8.8 in the next couple of weeks. ive got a C4 that needs to be built but will be installed over the winter. gonna go ahead and do the gear swap. need to know around what gears to use with the 3 speed auto. 26-28 tall tire. stock motor with tfs stage 1 cam, edelbrock performer intake and holley 600 4bbl. after the winter hopefully ill have a set of heads and a better intake/carb. ill be spraying the car also if that makes a diff. maybe somebody has a good recomendation for a set of gears.
![]() 90 Ford Mustang 5.0 T5- BROKE 1.9 60' on street tires13.64 @ 101 MPH 89 Ford Mustang coupe- http://www.youtube.com/watch?v=1nIrzcQz3_8 |
1989 Mustang Gt
Run me and find out!!!
1990 Mustang GT
13.64 @ 101 MPH
ive been looking for the formula kinda like, with this gear ratio and this tire size ill be going this speed at this many rpms.
#4 | |
This is no different then the link already shown but this is the formula used with wheel circumference (26 or 28 in your example x 3.14). RPM = Axle x Trans X 1056 X MPH / Wheel_Circumference MPH = RPM X Wheel_Circumference / Trans X 1056 X Axle Axle = RPM X Wheel_Circumference / Trans X 1056 X mph
98 Cobra
go with 4.10s
Well that is the question. I think he wants the "right" rpm's at the end of the track. For some people, 4.10's and a 26 inch tire MIGHT be right but you wouldn't know unless you have an estimate of HP or something to get the rough estimate of the expected speed at the end of the 1/4 and what RPM's the car is still making decent power.
Example.. With a 26 inch tire and 4.10 @ 110 mph would be 5800 RPM. A 28 inch tire would be 5400 RPM at 110 mph.
1989 Mustang Gt
That is true! Im pretty sure theres a calculator on another site I go to, but I havent been able to get on there for like a week... they are having technical difficulties I reckon
1990 Mustang GT
13.64 @ 101 MPH
gonna go with somethin shorter than 4.10's. like higher number. thanks for those nolife
Threads Similar to: Gear calculations
| Gear to gear on a Mach | stangless24 | 4V / SVT | 25 | June 11th, 2008 06:24 PM |
| Cam gear and camshaft position sensor gear... | 99v6stang | V6 Mustangs | 17 | January 17th, 2008 02:00 PM |
| Gear Calculations | jbm5781 | 96-98 | 7 | September 18th, 2007 03:00 PM |
| 4.30 Gear to much gear for street use/daily driver? | Bigb2000GT | 99-04 | 10 | March 28th, 2007 05:22 PM |
