What heads to go with an F303 cam?
I have a guy who is willing to sell his f303 cam to me for 80 bucks. I figure thats a good deal. I wanted to cam my engine and I think this would be a good start as far as being cost effective. What Heads could I run with this cam and also Rockers? I am looking into AFR and TW heads. Now mind you, I know JACK about lift degrees and all the other nubers. LOL. Still learning the relationship. But I want to run an F cam with a good head. What do you guys think?
302, Cobra upper and Lower Intake,UDP's,BBK Shorties with Flow Dumps, SMog Delete,CAI, 70mm TB, K&N Filter, Timing 14 degrees, Lowered 1.5, 3.73's, Nitto Dr's. "Its not that there is ever too much Horsepower, but not enough traction."
1992 Lx
11.39@119.24
i think if youre gona run 1400 dollar heads why cheap out on the cam
1989 Mustang Gt
Run me and find out!!!
+1... try to find some gt40's...
I thought about that as well.. But I wouldnt be able to run my current Headers with the GT40...Well from what I have heard. Is that true? I have some BBK Shorties
1993 5.ohhhh
12.97 @140mph
If your using ford parts allready like the cobra intake plus that fcam, just go with gt40ps on some 1.6 roller rockers. While you down their get some hardend pushrods, and maybe some fresh lifters. And u can run bbk headers on the gt40's. I have an fcam gt40ps and a cobra intake my self. Just go buy some 1993 cobra plugs. I think the plug boot on cylinder 7 will burn up. Get the 90 degree boot from the dristibutor side of the spark plug wire and and take off the normal boot and put it their. That way you have two 90 degree boots. Thats what I did atleast.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
Like the sound of that. Well what headers can be ran with the GT40's? I am looking to put some Longtubes on.
#7 | |
1992 Lx
11.39@119.24
stop copying my combo!!!!!!!!!!!!!!!!!!!!! (besides the cam) with my no-name headers the only plug i have issues with is number 4, thats the only one i have a spark plug boot on And hows your car running dude?
#8 | |
1992 Lx
11.39@119.24
get gt40p's!
1993 5.ohhhh
12.97 @140mph
We finally got it to idle, drove it around to make sure it wouldn't over heat or anything; their seemed to be no problems in that department. Didn't get to fix my floating idle before a rocker arm bolt broke. I beleive it was on an exhaust valve. So it started backfiring through the intake. Tried to drill it out of the head on the car yesterday but the bit broke off in the bolt when I went to back it out. Ganna have a mechanic fix that, get my power steering working. I'm buying my chip, and 255 this week. Late november early december blower and tune fo shooo!
1992 Lx
11.39@119.24
dam dude i break a spark plug you break a fucking rocker arm bolt!! you buying an sct chip? like is that what the tuner around you uses? thats what i have even know its completely useless till i go get a retune (which is hopefully within 2 weeks or so)
LOLOL...93Hatch- Gotta start somewhere and since i am still learning, I will be borrowing a lot of you guys combos. Until I learn better.
So you can just get a boot for the plugs and it will work? I have found a lot of great deals on the GT40 heads but heard so much about the header isues. She is running good. I have to Change to belt because the Alternator pulley screw came off and the pulley moved....and you guess it, split the belt. So I am replacing that right now.
HAHAAAA that question wasnt even for me. Well now you know anyway.
1992 Lx
11.39@119.24
hahahah na dude its the typical budget combo! gt40's apparently dont have the spark plug issue of gt40p's, those are 2 diff heads, similar but not the same
1993 5.ohhhh
12.97 @140mph
Just that one cylinder like I said. But the the side of the sparkplug that goes onto your distributer uses a 90 degree boot, just rip one off, and put it were the normal boot goes after taking the normal boot off.
Well, That would be a great budget. There are guys selling them for around 250-300 and then I can pick up a cam for 80, then another 100 for some rockers. Nice. How much of an gain do you think that would be?
1992 Lx
11.39@119.24
ill have some dyno numbers up in a few weeks, just waiting for my friend to get me some new o2 sensors from ford then im goin back for a retune
and heres a pic of the only plug i have issues with, but with the boot on it it works perfect
1993 5.ohhhh
12.97 @140mph
You will prob make 260 to possibly 280 maybe 290. But expect 270. I think thats what 93 hatch made. If your motors in good condish assuming. Somefoxes are old and just dirt slow. The motor that came in my 93 with intake exhaust and 3:55's prob would of ran a 14.8 at 92 if I was lucky. But on a slick you should be a 12.90 car then maybe some 11.90s if you get on the spray.
1992 Lx
11.39@119.24
dude with a fucked spark plug i made 226whp and 266wtq hahahah so yeah thats why im going back, car trapped at like 93mph runnin like dick now its trapping 104 untuned so im hopin for around 270
Nice...That works. That doesnt look too bad at all.
Those are decent numbers. My goal right now is 12sec. It has 75K on the motor so its in good shape as far as I can see. I order soem Nitto DR for the rear yeaterday. Wondering how they will hook. The Spray is definitely coming soon.
Nice...at 104 what was your ET?
Threads Similar to: What heads to go with an F303 cam?
| F303 cam in a stock 302 any problems? | cybertech | 5.0 Mustangs | 29 | August 14th, 2008 09:14 AM |
| f303 cam at .50 | worlz08 | 5.0 Mustangs | 3 | May 28th, 2008 09:37 AM |
| Looking at the F303 cam | 94stangGT50 | 5.0 Mustangs | 5 | April 5th, 2008 03:27 PM |
| Heads and cam | j2000_guy | 94-95 | 10 | April 7th, 2007 08:35 AM |
