internals for nitrous
Old November 13th, 2008, 01:14 AM   #1
chaosstangman is on a distinguished road
Im looking to get a stroker kit for a motor wanting to build (408) and i think that at some point i will run a decent shot of gas 100+and want my motor to be able to handle it with no problem. This will be a carbed motor and i know usually with nitrous everyone says forged is the way to go. I will have forged pistons and rods is it vital that the crank is also forged? Btw the car will mostly run all motor just on the gas when im feelin like i need an extra kick lol
Old November 13th, 2008, 01:28 AM   #2
RIP Justincredible! God Speed
Justincredible's Avatar
Justincredible is on a distinguished road
Don't lie to yourself....once you spray it...you will want to spray it all the time. Its like crack cocaine.....it only takes once.
As far as the short block goes... a forged crank never hurts... but I have ran a stock cast crank that lived longer than the block did (cylinder wall cracked), in a 71 block. Its my opinion that in moderate rpm applications (less than 7000rpm) that a properly prepped cast crank is as strong at the production block.
I do recommend forged pistons and a good set of "nitrous friendly" rings with the proper ring gap, gaped for the amount of nitrous you plan on running.
9.91@ 134mph 1/4 - 6.17@ 109mph 1/8th - 1.33 60' - Stock ECU & Stock Suspension......and getting faster .
BIVENS RACE CARS FTMFW!!!
Old November 13th, 2008, 02:37 AM   #3
Listen to this man, he knows his stuff.
[SIGPIC][/SIGPIC]
[B][U]MM Sapper Squad[/U][/B]
Old November 13th, 2008, 08:14 AM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
For 100hp of nitrous you need nothing more than stock parts. You won't start needing forged pistons until you are up around 150+ and rods and crank you won't need until long after that. However 408 kits are so common and inexpensive now that its harder to find a kit without forged parts. Since your doing a 408 I'd get a kit from Woody or CHP with all forged parts. You probably won't break a cast crank but I think a forged crank is going to help bearings and everything else live longer by not flexing as much and probably run a little smoother.
Old November 13th, 2008, 01:26 PM   #5
dragchik01's Avatar
88
8.90@151
dragchik01 is on a distinguished road
if ur buyin the stroker, just go all forged.. it will last in the long run..
T's Racing Vids: www.youtube.com/racrchik
88 Stang Single Digit Club
69 Camaro 9 Sec Club
Old November 13th, 2008, 01:39 PM   #6
mustangsoldier's Avatar
1993 Mustang
we'll find out when i come home from iraq.
mustangsoldier will become famous soon enough
shut up before i punch you in the throat
Threads Similar to: internals for nitrous
Internals. Elder 4V / SVT 5 April 27th, 2008 12:52 AM
? about internals Squints 5.0 Mustangs 5 April 25th, 2008 01:38 PM
Internals droppedbass87 General Tech 23 November 14th, 2007 03:35 PM
Internals 01silversnake 99-04 9 October 17th, 2007 07:57 PM
01 GT Internals MnrlGry01gt 99-04 12 November 13th, 2006 12:59 AM
