Opinions on roller rockers
Old November 13th, 2008, 03:30 AM   #1
STREETFIGHTER50 is on a distinguished road
Are COMP Pro Magnums the best? Anything better under the $300 price range?
2 red Notches
1 70mm Turbo'd
1 Si-Trim'd
Turbo is FS/TR: http://www.californiafords.com/ubb/u...c;f=5;t=090443
Old November 13th, 2008, 08:09 AM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Yes the Pro Magnums are good and probably the best you are going to get for $300 or less.
Old November 14th, 2008, 12:05 AM   #3
Brian@PAR's Avatar
Brian@PAR is on a distinguished road
Comp has a GOLD Race Rocker that will probably be more than enough for you. If you need more then they can handle then you should probably be stepping up to shafts. They are successfully running in 8000 rpm motors with over 500 lbs of spring. I run them in a 195cc headed 306 with 450 lbs of spring shifting at 7K.
259.95
PeteAndersonRacing
Threads Similar to: Opinions on roller rockers
Roller Rockers 95blackbeauty 5.0 Mustangs 1 June 17th, 2008 12:39 AM
1.6 or 1.7 roller rockers 89lx 5.0 Mustangs 6 June 14th, 2008 07:42 AM
roller rockers? superman5.0 5.0 Mustangs 7 July 26th, 2007 11:51 PM
Roller rockers? aj28 V6 Mustangs 7 July 15th, 2007 08:17 PM
new roller rockers 03stanger 5.0 Mustangs 51 March 19th, 2007 10:50 PM
