LinkBack (1) | Thread Tools |
1989 Mustang GT
14.01 @ 103..... :(
any one running boost?
What is a safe amount of boost to run on a stock fox ? (5.o)
![]() vortech s-trim off road h pipe super 40's steeda tri-ax c.a.i. 3.73s subframe cnntrs 255er |
1993 5.ohhhh
12.97 @140mph
10 pounds, if your lucky 14 psi.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
1989 Mustang GT
14.01 @ 103..... :(
if say i got the vortech 5-6 psi kit and ran 8 psi w it i should be fine then? it has no entercooler but running such low bost is that ok ? at least till its affordable
2002 Gt
Not Slow
![]() iTrader: 1 reviews
yes,. you'll achieve more power with an intercooler,. but in your case,. the vortech will be fine all day
2k2 Gt Eibach pro kit, bbk cold air, exhaust, 4.10s, 6k hid's |
1989 Mustang GT
14.01 @ 103..... :(
so lets say igo no intercooler for a few months runnin 8-10 psi i should be fine even on i 140000 engine and no intercooler? it is still strong as most foxs are. o and also is the intercooler soully for the lower intake temps for more power? not to be safer correct?
2002 Gt
Not Slow
intercooling is made for both,. safety and power
1989 Mustang GT
14.01 @ 103..... :(
how bad of a risk is it running with out one ?
2002 Gt
Not Slow
at the lower 5-6 psi,. its not as much of a problem,.. upon heading to the higher boosts it becomes more of an issue
1989 Mustang GT
14.01 @ 103..... :(
so if i stay under ten is that ok ?
2002 Gt
Not Slow
i would love to say yes, but it really all depends,..
1989 Mustang GT
14.01 @ 103..... :(
ok well that kit comes with brackets, blower and fmu, basically if i picked that up what else is nessasary bigger fuel pump?
2002 Gt
Not Slow
maybe some injectors
2002 Gt
Not Slow
that kit's only rated to 275hp,.. injectors may not be necessary,. the pump would be a good idea though,. 255'er
1989 Mustang GT
14.01 @ 103..... :(
whats a 255 run
12.8@103... stock motor
11.8@113...150 shot
how hard is it to go to summit and look up prices on fuel pumps?
answer: not very |
1990 Mustang GT
13.64 @ 101 MPH
Summit Racing - High Performance Car and Truck Parts | 800-230-3030
also, how much safe it will be at a certain PSI of boost is entirely up to the tune. you could run 3 PSI and have a shit tune and blow the motor. by adding boost you add the amount of air that goes into the engine therefore justifying the need for more fuel. if you dont compensate for the added air you will lean your motor out and more than likely fry the pistons. get a walbro 255 and one size up injectors to be safe and get it tuned. 6-10 PSI should be fine as long as the tune is safe and you have enough fuel.
![]() 90 Ford Mustang 5.0 T5- BROKE 1.9 60' on street tires13.64 @ 101 MPH 89 Ford Mustang coupe- http://www.youtube.com/watch?v=1nIrzcQz3_8 |
I get about 11psi on a V1 S-trim with no intercooling on a Ford crate motor (not much different than the production 5.0 engine). Holding up so far. My current "tune" is safe with 1.25-1.5 degree timing retard per pound. If I do anything else, I might consider a methanol kit and reducing the retard.
98 Cobra
the 19# injectors are only rated to 225 if anything you need to go with some like 30# so that u have room to improve, u will need a pump and injectors. u can make power all day but a car with slicks gears and a high stall some suspension and the basics will probroly take u all day. putting down times is more than just high hp and torque
1989 Mustang GT
14.01 @ 103..... :(
hey robot? i guess thats ur name maybe he was replying quickly and i just asked ? idk who pissed in ur cheerios this morning but he didnt have a problem answering my question ease up.
#20 | |
1989 Mustang GT
14.01 @ 103..... :(
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/97355-any-one-running-boost.html
| any one running boost? - Page 2 | This thread | Refback | November 14th, 2008 01:05 AM | |
Threads Similar to: any one running boost?
| Got Her Running, But wont stay running...help? | Speedstang302 | 5.0 Mustangs | 10 | August 28th, 2011 05:58 PM |
| How Much Boost? | Baja_XJ | 2.3 Mustangs | 21 | December 22nd, 2007 08:48 PM |
| HOW MUCH BOOST YOU RUNNING | 05mustang_TT_charged | 2005 - 2010 | 60 | August 23rd, 2007 10:32 PM |
| how much boost??? | 9stang1 | 5.0 Mustangs | 5 | December 5th, 2006 05:32 PM |
| Turbo Boost vs Super Boost | droppedbass87 | General Tech | 12 | October 16th, 2006 09:56 AM |
