#21 |
1990 mustang gt
eventually
i get a vibration too around 2600 but its only in 5th gear and chills out at around 3400
1990 gt 5.0 Mac Performance 76mm straight shot intake 70mm Accufab tb and egr spacer Trick Flow Track Heat u/l intake 3.55 gears MSD distributor, Blaster Coil, and 8.5mm wires |
#22 |
12.8@103... stock motor
11.8@113...150 shot
throw a different balancer on there
#23 |
1988 lx
9.68@142
0 chance. everything was bought bran new the stroker kit called for a 28oz and the damper is also a 28oz if there was a 50oz flywheel it wouldnt work.
and yes i am 10000000% sure the flexplate i have on there is 28oz i have 3 sitting here 2 28oz and 1 50oz and there is a big difference in the size of the weight,the box on the TCI flexplate also says 28oz 164t.
#24 |
1988 lx
9.68@142
why the balencer on there is bran new and worked fine with the origional flywheel.
the rotating assymboly was balenced to the damper and flywheel if i change the damper i risk making it worse
#25 |
good luck, just make sure u do it right this time so u dont have any more problems!
#26 | |
1988 lx
9.68@142
#27 |
11.8@113...150 shot
did you have the new flywheel balanced to the original flywheel?
on an externally balanced engine if you change either the balancer or the flywheel you need to have the new one balanced the same as the old one. you also should have indexed the position of the original flywheel and make sure when you put the new one on that it goes on the same, if you did not mount it the same, it will throw balance off. on an internally balanced engine this is not an issue, you just have the flywheel balanced by itself. |
#28 |
1988 lx
9.68@142
no i did not have the new flexplate balenced th the old flywheel and i think that is what is throwing it off.
#29 |
11.8@113...150 shot
yeah, thats the problem.
guaranteed. |
#30 |
1988 lx
9.68@142
thats all it can be now.. i have done everything else
it ran smooth as all hell with the 5 speed i switched it to an automatic and it vibrated. i ran it with nothing but the flexplate being the only thing different and it still vibrates. so unless something inside the motor effed up while it was sitting for a month (motor has about 1500 miles on it) then it is the flexplate. the problem is i sent it to florida but it was to a friend and he hasnt used it yet so he is gonna send it back.
#31 |
you lucked out there on the price. congrats
#32 | |
11.8@113...150 shot
what motor is it? what times you looking for? |
Threads Similar to: GOT HER BACK TOGETHER(for the most part)
| Notch back or Hatch back | ponyonsteroids | 5.0 Mustangs | 59 | January 19th, 2012 05:49 PM |
| Are you doing your part, I am....... | GTsetGO | The Clubhouse | 27 | June 10th, 2008 06:29 AM |
| And some more part 2! | JAY'SRED02 | Pictures | 3 | October 7th, 2007 05:50 PM |
| How Much Hp will these new Part get me.. | Speedstang302 | 5.0 Mustangs | 11 | September 13th, 2007 11:41 PM |
| Questions about Axle back & Cat back exhaust | Scion | V6 Mustangs | 2 | October 9th, 2006 07:44 AM |
