1988 lx
9.68@142
GOT HER BACK TOGETHER(for the most part)
got my converter back today from redneck performence (2 nd converter) took it stright to the machine shop and put it on the lathe to see if everything was centerd this time. everything looked pretty good. got home put everything in it starts up fine doesnt seem to vibrate anymore just a little from the roar of the motor and the solid mounts but i think its fine i am gonna bring it to the machine shop tomorrow to have the owner check it out.
my car no longer leans to the left after the new control arms and bushings. though my alignment is off now after changing the front bushings my steering wheel sits crooked even though i didnt adjust with the tie rods but i am going to take it to the shop to have an alignment done its lifetime alignment for 89.00 so ill just take it back when i get the new rack.
1986 toyoya corolla AE86
LOL @ WTF
lifetime alignment?! Where!?
1993 Mustang
we'll find out when i come home from iraq.
good shit
shut up before i punch you in the throat |
1988 lx
9.68@142
12.9 @ 105
That's a good price. I used to work at Firestone in CT a few years back. We used to charge 110 if i remember correctly.
good news man
1990 mustang gt
eventually
lifetime is the way to go.. do they adjust cc plates too?
1990 gt 5.0 Mac Performance 76mm straight shot intake 70mm Accufab tb and egr spacer Trick Flow Track Heat u/l intake 3.55 gears MSD distributor, Blaster Coil, and 8.5mm wires |
1988 lx
9.68@142
i called today its actually 119.00 it was 69 for the one time. yeah they will do everything and even if i change my rack and switch to a tubular front end they will do it all for free.
2002 Gt
Not Slow
![]() iTrader: 1 reviews
thats a deal
2k2 Gt Eibach pro kit, bbk cold air, exhaust, 4.10s, 6k hid's |
1988 lx
9.68@142
do it all as in the alignment
1992 Lx
11.39@119.24
so u racin tomorrow at domestics vs rice?
1988 lx
9.68@142
maybe if everything goes well and they say my car is not vibrating anymore
1992 Lx
11.39@119.24
ooooooooooooohhhhhhhhhhhhhhhhhhhhhhhh
1988 lx
9.68@142
well i am not going... it is still effin vibrating.... so after 2 converters and 2 flexplates it still does the same shit starts vibrating about 2700 and gets worse as the rpm's go on,
there are only 2 things left it could be ither the transmission itsself or the rotating assymboly was balenced to the flywheel but i will narrow it down this weekend. i am going to bolt the transmission up without the converter in it. if it still does it its the flexplate needs to be mtched to the old flywheel. if it doesnt then its the transmission itsself.
What weight balance is the 347?
PeteAndersonRacing.com |
12.9 @ 105
What does it do when you rev it in neutral? Is the vibration only felt as you drive under a load. I would think if you can feel it in neutral or park the problem is on the engine side. When did the vibration begin?
#17 | |
1988 lx
9.68@142
its a 28oz
it had no problems prior to switching it to an automatic. i have had 2 differnt flexplates in it (yes they are the correct weight) and 2 differnt converters. the only things it can be ither the transmission itsself ot what i think it is, when the rotating assmboly was balenced it was balenced to the flywheel and the flywheel was a cheap one and proly was not standardized so when i switched to a differnt flxplate it threw it off. i will find out when i put the transmission back in with no converter and if it still vibrates then that is it and it will be an easy fix ill have my buddy send me my flywheel back and i will have my new flexplate matched to the old flywheel. if it doesnt vibrate then i send the transmission back.
Atomized
shit man hope you get it soon i wana see some 10's
1988 lx
9.68@142
well me and james pulled it back out for the 4th time this time we put it back up without the converter and it still vibrates so that narrows it down to the flexplate and flywheel not being matched... i dont see how that is possible beings they are both 28oz but the flywheel was a cheapie and the rotating assymboly was balenced to it so we should be able to just match the flywheel and flexplate and it should solve the problem so ill keep you updated..
You sure its 28 oz...no possibility its 50 oz?
Threads Similar to: GOT HER BACK TOGETHER(for the most part)
| Notch back or Hatch back | ponyonsteroids | 5.0 Mustangs | 59 | January 19th, 2012 05:49 PM |
| Are you doing your part, I am....... | GTsetGO | The Clubhouse | 27 | June 10th, 2008 06:29 AM |
| And some more part 2! | JAY'SRED02 | Pictures | 3 | October 7th, 2007 05:50 PM |
| How Much Hp will these new Part get me.. | Speedstang302 | 5.0 Mustangs | 11 | September 13th, 2007 11:41 PM |
| Questions about Axle back & Cat back exhaust | Scion | V6 Mustangs | 2 | October 9th, 2006 07:44 AM |
