LinkBack (1) | Thread Tools |
#1
1986 LX
none yet
belt tension problems
I need help. With my intake the way it is I cant put an ac delete of any type like I thought maybe i could have. it will put my tensioner right on the intake. Has anyone ever messed with moving the tensioner to different places or anything of the sort? Im at a loss. Or how do you route a belt and bypass the power steering? Thats another route I may take. But how would a tensioner work there? Any thoughts are greatly appreciated at this point. I have some pics to show what Im working with
Take the pipe off then install the belt...am i missing something
PeteAndersonRacing.com |
1986 LX
none yet
Sorry guess I wasn't very clear. I can install it where it is. But the tensioner doesn't hold any tension on the belt because there is no ac pulley or anything to keep the belt up. If I install an ac bypass pulley the belt will pull the tensioner up into the intake pipe. so my dillema is clearance. Where can I move or modify the tensioner where it will hold pressure on the belt?
Get a power steering relocation kit.
1986 LX
none yet
thats the same as an ac bypass pulley as far as the belt location. With the belt being up higher, in this case where or near where the ac would normally be, the tensioner will be pulled up into my intake pipe. thats where I need to see about moving the tensioner to a different place. I may ditch the tensioner and go with a turnbuckle pivot set up on either my alternator or power steering
I see what your saying.......If you do the turn buckle set up wont you have more of a problem with belt clearance?
1986 LX
none yet
Possibly. thats another concern of mine. Im not sure what would be the best way. I was also thinking of maybe finding a way to use the tensioner upside down where the smog pump used to be.
By looking at the pics that pipe may have to be rerouted or look at some March set ups.good luck and keep us updated.
98 Cobra
i dont see why u couldnt put it in the bracket were the smog pump was but it would take some modification but not hard it would seem
12.8@103... stock motor
11.8@113...150 shot
get the trickflow a/c delete
moves the tensioner to where the ac compressor used to be... damn... 2 threads in a row where my post is the exact same |
11.8@113...150 shot
on second thought just ditch that pipe...
seems like a lot of headache for something so simple |
89lx,93lx & 88gt
go to cj pony parts and chech out the tech article on belt length. if you've also removed your smog pump you would need a 72 in belt.
1986 LX
none yet
1986 LX
none yet
1989 Mustang LX
10.98@126.7 NA
Ditch the water pump for electric, go to a manual rack and get a March kit for the alternator. It will mount low on the left side of the motor. No more problems.
Never fast enough.
1986 LX
none yet
I have wanted to go with a manual rack. havent really thought much about the electric water pump. Maybe in the future. But i guess for now the slightly more cost effective answer is what Im looking for.
11.8@113...150 shot
1986 LX
none yet
looking to buy sn95 5.0
try running a slightly shorter belt, like a 70 inch belt
1986 LX
none yet
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/97429-belt-tension-problems.html
| belt tension problems | This thread | Refback | November 14th, 2008 07:32 PM | |
Threads Similar to: belt tension problems
| Belt chirp problems | genericcobra | 4V / SVT | 0 | October 6th, 2008 08:07 PM |
| 04 cobra belt problems | killerSVTcobra | 4V / SVT | 8 | August 18th, 2008 06:42 PM |
| Belt Problems | NYMustang21 | V6 Mustangs | 1 | July 13th, 2008 01:02 PM |
| Rear side seat belt problems | Archy88 | General Tech | 1 | October 9th, 2007 03:09 AM |
| Tension Pulley | MustangMatt96GT | 96-98 | 8 | April 24th, 2007 10:57 PM |
