LinkBack (1) | Thread Tools |
#61 |
1990 LX hatch
Thats less of a ratio than I was expecting. Badass motor, badass chasis, and a badass driver, I'm assuming.
They should have an all out stock shortblock class, any power adder, 10.5, no boss, or 351... I think that would be cool, it would prolly put the tracks cleanup crew at work alot more tho.
#62 |
1990 Ford Mustang GT
12.0 @ 116
Compression Ratio im not 100% sure on, the guy i bought the car from said it was something like 10.5:1 or 11:1 some where in that area...it is a CHP shortblock, nothing too fancy, just a 2 bolt main with a girdle...but im gathering the AFR's are known as garbage around here...
#63 |
12.0 @ 116
After reading more...i realized that question was not directed at me...shutting up...
#64 |
1995 Mustang GT
Don't buy that Comp Cam. If you are truly disappointed with your combo, you need to just start by completely re-doing your top end. Bigger heads for starters... I think the AFR 205's would be a good choice, but that's just my opinion. The biggest trick flow heads you can find would be even better... As far as an intake goes... look into the Eddy Performer RPM II... they have great flow numbers and I have a friend with a 347 in his 95 who switched to an RPM II from his track heat intake and picked up around 20 rwhp. Please don't put another off-the-shelf cam in there. AFTER you get the heads and intake that you want (you could port/polish them to match too...) then call up Jay Allen at Camshaft Innovations and have him custom grind you a cam that is specific to your combo. Guaranteed you will be surprised at how much power you make. Good luck man...
#65 |
08 GT-92 lx
A Holley Systemax added 42rwhp to my set up. Additionally, it added 38rwhp to my friend's and he has an "F" cam. I have a Comp Cams XE266HR. Both are 331 C.I. with AFR 185's, full exhaust, 3.73, etc and both run low 12's granny shifting on drag radials.
Hope it helps. |
#66 |
1993 5.ohhhh
12.97 @140mph
Thats pretty bad, and no, not bad in a good way.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
#67 |
A systemax added 42rwhp to your naturally aspirated 12 second car? Lets see some dyno sheets.
#68 |
12.0 @ 116
i gained almost 30 horsepower by going from a BBK SSi to a Holley Systemax, thats after a tune, before a tune, i went from 318 to 338 so thats 20HP right there...
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/97445-331-horsepower-capability.html
| 331 Horsepower Capability | This thread | Refback | November 14th, 2008 10:51 AM | |
Threads Similar to: 331 Horsepower Capability
| 331 Setup | hitorx | 5.0 Mustangs | 3 | April 27th, 2008 12:12 PM |
| 331 | thewayshemoves | 99-04 | 20 | November 24th, 2007 11:54 AM |
| 331 Or 347 | e3sean | 5.0 Mustangs | 43 | November 20th, 2007 11:45 PM |
| Mach 1 capability | DSG04GT | 99-04 | 10 | October 29th, 2007 04:17 PM |
| Ford SB Production Block Capability | Zak | 5.0 Mustangs | 4 | March 30th, 2007 08:15 PM |
