1990 mustang gt
eventually
help fast
what are the power steering lines comin from the rack and pinion called with the metal fittin goin to the cooler b4 i punch this bitch at the conter at kragen
1990 gt 5.0 Mac Performance 76mm straight shot intake 70mm Accufab tb and egr spacer Trick Flow Track Heat u/l intake 3.55 gears MSD distributor, Blaster Coil, and 8.5mm wires |
low pressure line?
The high pressure line will have 2 nut type connections where it runs into the power steering pump (hence high pressure).
The low pressure line will be held in place with a hose clamp or something similar since it is the "low" pressure side.
You haven't failed until you stop trying. |
1990 mustang gt
eventually
its the hard line that comes out of the rack that i need
Threads Similar to: help fast
| Need Help Fast | wannabeimportkiller | V6 Mustangs | 34 | January 13th, 2008 08:40 PM |
| Need help fast! | dmachine22 | 99-04 | 3 | October 19th, 2007 12:30 AM |
| need help fast | mikethetigerrr | V6 Mustangs | 10 | October 3rd, 2007 07:41 PM |
| how fast can we go? | Steve O | 99-04 | 8 | October 3rd, 2007 07:52 AM |
