power steering
Old November 14th, 2008, 11:26 PM   #1
chickenbot's Avatar
1990 mustang gt
eventually
chickenbot can only hope to improve
power steering
has anyone ever changed out thier lines before? and if you have are they supposed to be loose on the rack and pinion? help plz shes bleedin like a stuck pig
1990 gt 5.0
Mac Performance 76mm straight shot intake
70mm Accufab tb and egr spacer
Trick Flow Track Heat u/l intake
3.55 gears
MSD distributor, Blaster Coil, and 8.5mm wires
Old November 14th, 2008, 11:31 PM   #2
3521's Avatar
1988 Gt Cali car
3521 is on a distinguished road
what the fitting is loose or the line while the fitting is tight?
Old November 15th, 2008, 08:12 AM   #3
chickenbot's Avatar
1990 mustang gt
eventually
the line is loose while the fittin is tight. i just put a new pressure line on it and now its worse than before
1990 gt 5.0
3.55 gears
Old November 15th, 2008, 01:20 PM   #4
3521's Avatar
1988 Gt Cali car
are some the threads boogered up?, I'd clean it up the best I can (talking about draining the fluid) and look to see whats causing the issue, if I couldn't find any issues with the line. I d be looking at the seat in the rack and pinion and the threads for some thing stupid like grit and if the seat is hurt in some way
Old November 15th, 2008, 02:24 PM   #5
RIP Justincredible! God Speed
Justincredible's Avatar
Justincredible is on a distinguished road
Did you install the Teflon seals provided with the new rack?
9.91@ 134mph 1/4 - 6.17@ 109mph 1/8th - 1.33 60' - Stock ECU & Stock Suspension......and getting faster .
BIVENS RACE CARS FTMFW!!!
Old November 15th, 2008, 05:38 PM   #6
chickenbot's Avatar
1990 mustang gt
eventually
the seals are all on there and that know of the seats are clean.. couldnt really see em while had her on the lift
1990 gt 5.0
3.55 gears
Threads Similar to: power steering
power steering skid6 5.0 Mustangs 6 August 11th, 2007 06:11 AM
Power Steering jonnotch 5.0 Mustangs 1 April 25th, 2007 02:45 AM
Decreasing power steering pump pressure for tighter steering 83 5.0 5.0 Mustangs 6 January 7th, 2007 08:24 PM
power steering terribleonexx88 5.0 Mustangs 4 December 27th, 2006 07:50 PM
Power Steering 232stang V6 Mustangs 5 November 14th, 2006 06:10 PM
