LinkBack (1) | Thread Tools |
#1
04 mustang gt
7.21 @ 98
worth buying???
i found a 2.3 4cyl foxbody mustang running i assume (says "gets good gas mileage") for $125...is it worth buying?? i don't want to keep the 2.3. i would like to put in a 302 or maybe a 351. whatever is cheap and easy to work on (and whatever has cheap engine parts) i don't wanna have to spend a ton of money on an engine though (i don't mind buying a stock motor) when i can just a buy a v8 foxbody in the first place...
so would a 302 bolt right in? or would it require some fab work (another thing i'd like to avoid)? if it will bolt right in then fine but otherwise i'd rather get a foxbody that already has a v8 and then build the current motor. and if it would bolt in then what about the transmission? would i need a new one? i saw that the 2.3 forum doesn't get many posts...and this is sort of a 5.0 topic since i'd like to do the 302 swap
![]() cams + 150 shot |
I think its better to just get a fox with a 302 already in it thats just my opinion
![]() 99 svt cobra rims/cai/autolite plugs. Soon to have a 1990 mustang gt fox ![]() |
And it will save you the hassle of doing a motor swap and all!
93z, 96gt
dude, for 125 bucks snatch that up right now
you could scrap it for 200
![]() 99 BMW m3 90 BMW 525i 93 Z28 93 Jeep Cherokee |
1990 Mustang GT
13.64 @ 101 MPH
you can find foxes relatively cheap. they are a dime a dozen. just make sure you check the torque boxes and floor for cracks. the torque boxes like pulling away from the body.
![]() 90 Ford Mustang 5.0 T5- BROKE 1.9 60' on street tires13.64 @ 101 MPH 89 Ford Mustang coupe- http://www.youtube.com/watch?v=1nIrzcQz3_8 |
04 mustang gt
7.21 @ 98
i don't wanna scrap it. just wanna know if it would be worth it for a v8 swap.
#7 | |
2007 Mustang GT
Hell yeah buy it for $125!!!
![]() 2007 Mustang GT KB Charged |
04 mustang gt
7.21 @ 98
i think i may do it. and i have been looking at some 302's and they are cheap...for example there is a complete 302 WITH transmission for $700
so the total would be 825 which is probably less than most of the 5.0 foxes i've seen. i saw ONE for $600 ("needs a little work") but turns out it already sold. so will a v8 bolt in? most foxes are around 1K or more. i did see a few for 800 and 850 but they are gone now.
You will find out how the money adds up..... will not cost 125 plus 700 for motor and tranny.....
Trust me
PeteAndersonRacing.com |
1989 LX coupe 5.0L
with the right motor mounts the v8 will bolt right into the 4cyl car.... ur need a few little things, all depends on what trans your going with and carb or efi
91 Mustang LX Fastback
We shall see when she gets done..
93 is right, it wont end up there...
You will need new motor and trans mounts, trans member, figure it all out, if its EFI, than youll need the harness, and body harness and comp. You will also want to swap in an 8.8 rear end, and if the trans dosent have a shifter youll need one of those to.. And beofre you know it, youve spent more than you thought.. Brett!
2003 MazdaSPEED Protege. Lava Orange with all the go fast parts 1991 LX. 2.3T in the works. 1977 Pinto Wagon. New motor combo in the works for 2012, C4, 4.10s, 150 pill. Et. unkown ![]() 1969 Impala. Needs a resto. Im Canadian, Eh! |
1993 Mustang
we'll find out when i come home from iraq.
+54618641348 for the brat. might as well just buy a stang w/ 5.0 already in. its going to add up to way more if you buy the 4cyl and do the swap
shut up before i punch you in the throat |
1992 Lx
11.39@119.24
shit id buy it just to drive around and jump dirt jumps in
1993 Mustang
lol good point 93.
1988 lx
9.68@142
it is worth spending the 1500-2500 on a 5.0 car i personally love the 85 even though i have an 88. the thing is you will have to redo the fuel system,all the wireing,suspension,motor swap,transmission,rear end, trust me. drive a 4cylender then drive a 5.0 (not just the power difference) but handeling too.
can it be done? hell yes and has been done alot. if you plan on building a car from the ground up and you just want a roller then buy it. if you think you are gonna buy it drop in a 5.0 and drive the hell out of it....think again. 125 is worth the body and interrior if its in good condition.
Moderator
Id snatch it up, clean it up and fix whatevers wrong with it, turn around and flip it, and put that towards a v8 car.
There's a reason Ford codenamed them the Terminator
91 lx convt
14.02@100
1993 Mustang
yea could definetly flip it for a profit and get an even better 5.0
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/97706-worth-buying.html
| worth buying??? | This thread | Refback | November 17th, 2008 01:12 AM | |
Threads Similar to: worth buying???
| Fuego Flash Tuner is it worth buying??? | HawkCrewchief | 2005 - 2010 | 15 | February 15th, 2009 08:31 PM |
| buying a treadmill is like buying bottled water | obdnanr | The Clubhouse | 18 | August 3rd, 2008 10:55 AM |
| buying a treadmill is like buying bottled water | obdnanr | The Clubhouse | 9 | August 2nd, 2008 12:47 AM |
| is this 99 cobra worth buying? | 94pacecarSVT | 4V / SVT | 11 | March 16th, 2008 06:54 PM |
| buying a new stang...think its worth it? details inside | djsylert | 5.0 Mustangs | 14 | September 21st, 2007 04:21 AM |
