Rear 4 lug disk brake swap questions.
Old November 18th, 2008, 03:45 PM   #1
ajb4507's Avatar
1990 Mustang GT
ajb4507 is on a distinguished road
Im planning on starting taking out the drum brakes and swapping in a set of disks i picked up for free when i bought my motor. I believe that the parts i have came from a cobra or turbo coupe not sure which. Any way i have heard that you need the axles that the calipers and brakes came with, is this ture? Also if anynone has done this before some pointers or tips would ve greatly apreciated.
Sticks and stones may break my bones, but a Chevy will never pass me
Old November 18th, 2008, 03:49 PM   #2
91 LX
13.7@101
yeah I hope someone knows about this cause i'm looking to do the same
Old November 18th, 2008, 08:58 PM   #3
1993 Mustang GT
Haggis13 is on a distinguished road
Send a message via MSN to Haggis13
It is not true if you buy a set of offset brackets for FOX length axles.
North Racecars Brake Solutions
Bart
93 Black on Black GT
Kenne Bell S/C
GIVE 'ER!
Old November 19th, 2008, 11:55 AM   #4
ajb4507's Avatar
1990 Mustang GT
so if couldnt i just build a 3/4 inch spacer to do the same thing?
Old November 19th, 2008, 02:16 PM   #5
ajb4507's Avatar
1990 Mustang GT
also i have the rotors the calipers and the mounting bracket. Is there anything else that i am missing.
Old November 19th, 2008, 03:36 PM   #6
1BADSTANG's Avatar
1BADSTANG is on a distinguished road
i did the rear disk brake conversion from ssbc, its a shitty set up. If you are doing it for free i have no advice but id put the money down and get that sweet wilwood rear conversion
Old November 19th, 2008, 06:56 PM   #7
1993 Mustang GT
You'll need new e-brake cables, adapter to fit the rear line to the hoses on the calipers, and adjustable proportioning valve and the plug to defeat the stock valve. A larger master cylinder helps (94-95 GT is good and cheap) I don't see a spacer working, as the bend in the bracket happens up over the axle shafts on the bracket - but I could be wrong and have been before.
Bart
Kenne Bell S/C
GIVE 'ER!
Old November 19th, 2008, 07:53 PM   #8
89lx,93lx & 88gt
old gray fox is on a distinguished road
you'll need 5 lug axles to run 17 in wheels to clear the calipers and you'll have to change your booster, are your rotors 11 in
Old November 19th, 2008, 08:15 PM   #9
1993 Mustang GT
No he won't - He's doing a 4 lug conversion. You need 17" rims to clear 13" cobra brakes.
Bart
Kenne Bell S/C
GIVE 'ER!
Old November 19th, 2008, 10:14 PM   #10
3521's Avatar
1988 Gt Cali car
3521 is on a distinguished road
I thought 93 was when the cobra came back after a little break and they were 5 lug? I'd be curious in looking in to sn stuff. I've read they where based on the fox with a diff wrapper so if thats true then would that mean a disk rear from a 94,95 car bolt in since the spindles are the low buck way of 5 lugging? Kill two birds with one stone on that one. That could be some thing to look into.
Old November 19th, 2008, 10:58 PM   #11
08 GT-92 lx
txbkr is an unknown quantity at this point
North Racecars Cobra Replica and Mustang Parts Connection if you need anything, try these guys out. I got my set up from them and it worked out well. My only complaint is the quality of the rotor; made in china.
Old November 20th, 2008, 11:59 AM   #12
Arctic Fox's Avatar
1989 GT
KB 2.1L Flowzilla
Arctic Fox will become famous soon enough
No, 93 Cobras were 4 lug, same size brakes as other V8s, but little different offset for disks.
93 Cobra R was 5 lug, 13" front 11.65" rear disk
Old November 20th, 2008, 02:33 PM   #13
ryans88gt's Avatar
You need offset brackets or cobra axles. One or the other.
16 inch wheels and 15 inch wheels will clear the 93 cobra style brakes (speaking from experience)
Old November 20th, 2008, 09:51 PM   #14
3521's Avatar
1988 Gt Cali car
Good to know, what about if a 94,95 rear axle as a whole will it bolt up?
Old November 20th, 2008, 11:37 PM   #15
ajb4507's Avatar
1990 Mustang GT
Thanks for all of the info. I dont know alot about the braking system which is why i needed to ask. Im going to have my one friend help me out who is a mechanic so hopefully we can do it right. Im going to try to use the stock axles so we'll see how that goes.
Threads Similar to: Rear 4 lug disk brake swap questions.
4 cyl swap...rear brake line Way_Fast_Whitey 5.0 Mustangs 14 September 6th, 2007 11:04 PM
5 lug 4 wheel disk brake conversion etony89 5.0 Mustangs 3 July 21st, 2007 11:48 PM
Rear Brake Questions Jojogunne 5.0 Mustangs 2 March 23rd, 2007 12:13 PM
4 to 5 lug and rear disk doorvip 5.0 Mustangs 3 November 21st, 2006 11:56 PM
4 To 5 Lug Convertion And Rear Disk doorvip 5.0 Mustangs 0 November 16th, 2006 06:11 PM
