thermostat stuck open? (not a Mustang)
LinkBack (1) Thread Tools
Old November 18th, 2008, 08:30 PM   1 links from elsewhere to this Post. Click to view. #1
nolife's Avatar
91GT, 88GT, 02GT
I don't frequent any other car forums so I figured I'd ask here.
My little 1.3 liter Ford Aspire I use as a commuter never freaking warms up. I did not mind until it started getting cold. The temp gauge never goes a fraction above C and the heat is not very hot. Is it possible for a thermostat to stick open? Maybe the engine is too small to generate enough heat but I don't remember it being this bad in the past winters
Old November 18th, 2008, 08:38 PM   #2
91cobra5.0's Avatar
98 Cobra
yes it could be that you need 2 replace your thermostat and any engine will get hot no matter the size
Old November 19th, 2008, 12:17 AM   #3
looking to buy sn95 5.0
MaPolley07 is on a distinguished road
Thermostats are cheap, go ahead and replace it. Any engine should get hot (as stated above) Also check the coolant sending unit or coolant temp sensor, could be bad as well causing the gauge to not read.
Might as well drain and change your coolant while you're at it, never hurts
Old November 19th, 2008, 08:46 AM   #4
nolife's Avatar
91GT, 88GT, 02GT
I'll swap it out this weekend. I noticed some valve train ticking on start up recently on it as well so I'm wondering if it has been running cold for a while and a little sludge is starting to build up. My comment about the small engine and not heating up was kind of a joke because the engine is only rated at 57HP.
Old November 19th, 2008, 10:14 AM   #5
91cobra5.0's Avatar
98 Cobra
your valvetrain will always make nosie, some engine oils quiet it down more than others. Your guage reading should not effect your engine or heater temp. If its not getting hot inside then its most probrobly the thermostat
Old November 19th, 2008, 11:31 AM   #6
Atomized
gotn20's Avatar
gotn20 will become famous soon enough
+1 tstat
Old November 20th, 2008, 10:25 AM   #7
forgot to mention Autozone can test your coolant temp sensor for free, might as well check out related problems/concerns while you are going to be replacing the thermostat. And stay with the OEM thermostat temperature or one step higher if you aren't getting it to heat up.
Old November 20th, 2008, 10:26 AM   #8
yojoe600's Avatar
yojoe600 will become famous soon enough
yea just get a new thermostat
Originally Posted by supermachone View Post
it was something like the tinman from the wizard of oz pinching off a tight fart...
Cat Club Co-Founder
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/98044-thermostat-stuck-open-not-mustang.html
thermostat stuck open? (not a Mustang) This thread Refback November 19th, 2008 08:52 AM
Threads Similar to: thermostat stuck open? (not a Mustang)
Driver door lock is stuck. Can't open door Help!!!! White 89 5.0 Mustangs 25 April 26th, 2011 12:49 PM
Wide Open Throttle Mustang Club Meet in NC ECUSVT31 Southeast 0 August 8th, 2008 01:39 PM
2002 mustang, stuck window motorhead6776 V6 Mustangs 12 September 8th, 2007 08:35 PM
Eibach Springs Mustang Open House Evil ESD Southwest 3 August 27th, 2007 02:08 AM
thermostat 88stang 5.0 Mustangs 8 April 21st, 2006 04:43 PM
