brake problems
LinkBack (1) Thread Tools
Old November 19th, 2008, 11:16 AM   1 links from elsewhere to this Post. Click to view. #1
r!ko88gtMEX's Avatar
1988 Ford Mustang GT
r!ko88gtMEX is on a distinguished road
brake problems
ok i'm having an issue with my brakes, the pedal's going all the way to the floor, it brakes, but i don't want to come to the point that the brakes will go out, i bleed the brakes.... , brakes good for about 20 driving minutes , or if i let the car sit for about 30 minutes, the pedal's the same way as before. what are the things i need to check out?? brake lines, brake cylinder, what else??
F!v3 pO!nT ... ooohhhh !! eL ZinKo-ZeRo..!!
Old November 19th, 2008, 12:52 PM   #2
1992 Lx
11.39@119.24
check all the lines for leaks and check your master cylinder to see if youre losing fluid
Old November 19th, 2008, 03:36 PM   #3
Nice 5.0's Avatar
1993
12.9 @ 105
Nice 5.0 is on a distinguished road
Sounds like a master cylinder. I think if anything else was bad then you would have no brakes at all.
Old November 19th, 2008, 03:57 PM   #4
1992 Lx
11.39@119.24
did you bleed them in the correct order?
Old November 19th, 2008, 03:58 PM   #5
Hunt_chevs's Avatar
2002 Gt
Not Slow
check your lines feeding to the front calipers and look for residue to see if the leak is there, if not its sounds like the master cyl.
Old November 19th, 2008, 03:58 PM   #6
Hunt_chevs's Avatar
2002 Gt
Not Slow
+1
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/98112-brake-problems.html
brake bleeder | Digg hot tags This thread Pingback November 19th, 2008 12:35 PM
Threads Similar to: brake problems
brake problems 99blkcobra 99-04 20 October 11th, 2007 11:45 PM
emergency brake problems usmcsawgunner 5.0 Mustangs 4 June 15th, 2007 01:26 AM
brake problems delindsay04 V6 Mustangs 4 January 15th, 2007 02:11 PM
I have Brake problems! mustangstud13 99-04 9 September 10th, 2006 11:18 PM
Brake Problems 00SoSlow General Tech 14 May 31st, 2006 02:49 PM
