302/347 or 351W
Old December 19th, 2006, 12:33 PM   #1
OTreborO is on a distinguished road
302/347 or 351W
OK, I have a 302, and have been thinking about stroking it to a 347.
I have also heard that I would be better just buying a 351W
I thought it was hard to find a 351W, and would all of the electronic crap fuel injection, etc etc hook up to it. I don't think I want to go to carb.
If I do the 302/347, I would like to take it apart myself, and put it back together. Is there some good books or articles on this? I have never torn an engine apart, so I would need a detailed manual. You know, stroking for dummies LOL
Thanks,
Trebor
"Those who forget the past are condemned to repeat it" Rev. Jim Jones
Old December 19th, 2006, 12:47 PM   #2
86er's Avatar
im not a huge fan of the 347, it changes the angle that the rods travel and it helps wear the motor out earlier, it will last a while, it just wont have the longjevity that a non stroked motor would.
Id go with a 351 personally thats just me, heads will swap, upper intakes will swap, but the lower wont, its a wider block than a 302 and you will need a different dizzy also
Just a truck
Old December 19th, 2006, 12:57 PM   #3
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
A 347 is a perfectly fine reliable engine. Rod ratios mean nothing. A 347 has less of a rod to stroke ratio than a 454 Chevy and that is one of the most reliable engines around. I've had many 347s and not one of them burned a drop of oil or had any premature wear issues.
A 351W is a better choice in my opinion. Only because the block is stronger and the ability to go over 400 cubic inches is there if you decide to do so in the future. Building a 351W will also be cheaper for the average street car because you can use the stock crank and rods and not worry about them failing. The deck height is 1.3 inches taller (9.5 vs. 8.2) but a 351W fits without a problem in a Mustang. You will need different headers and distributor as mentioned above. Many companies make EFI intakes for 351W engines.
Old December 19th, 2006, 01:08 PM   #4
What about the piston/pin issue
I looked at this one site, and they mentioned going with a 331 because of the close relation to the oil-ring on the piston to the pin????
http://www.fordmuscle.com/archives/2002/04/331/
351 blocks are very hard to find......................
Old December 19th, 2006, 01:13 PM   #5
Phone call
Hello this is "Fill in the name" Salvage.
You want a what? A 351 W.
Yes, you and everyone else......... dial tone.........................
Old December 19th, 2006, 01:14 PM   #6
86er's Avatar
Re: What about the piston/pin issue
there all over the junk yards down here, i counted 15 yesterday in two junk yards
Just a truck
Old December 19th, 2006, 02:40 PM   #7
5-0stank is on a distinguished road
i know... its not hard to find them. it is a little harder to find a roller tho
1995 GT::Sold!
Looking for another stang...
Old December 19th, 2006, 02:51 PM   #8
woody1 is on a distinguished road
351 blocks are dime a dozen, millions produced. There is nothing wrong with the 347, you can get 3 different rod lengths if you subscribe to the "5.400, 1.090CH pistons burn oil" theory. The only thing people forget with the 351 is hood clearance, headers, oil pan etc. If the little extra cost of the 351 does not bother you, thats the way to go.
Old December 19th, 2006, 05:43 PM   #9
RIP Justincredible! God Speed
Justincredible's Avatar
Justincredible is on a distinguished road
+1 for the 351.
I love mine.
9.91@ 134mph 1/4 - 6.17@ 109mph 1/8th - 1.33 60' - Stock ECU & Stock Suspension......and getting faster .
BIVENS RACE CARS FTMFW!!!
Old December 19th, 2006, 05:56 PM   #10
86er's Avatar
they make a conversion kit, its like 75 bucks or so
Just a truck
Old December 20th, 2006, 09:42 AM   #11
OK, so am I asking the wrong questions?
I call and ask for a 351W, and I get a long silence.
Should I be more specific?
Thanks,
Trebor
Old December 20th, 2006, 01:16 PM   #12
Tell em 351 windsor, ford made a jillion of them, if yu still get silence call them a dumbass.
Old December 20th, 2006, 01:19 PM   #13
+1
If you can...the 1971-1974 Windsor blocks were the strongest. They had slightly thicker main webbings.
Old December 20th, 2006, 02:23 PM   #14
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
69 and 70 351W blocks and cranks are the strongest, because they have a higher iron content. I have a 69 351W shortblock that has never been touched. Everything is standard, and I've tossed around the idea of selling it, but I haven't decided yet.
./___ _ ____ ___ \.
( ]]] _ _ O _ _ [[[ )
\_ o _ _____ _ o _/
|___| ......... |___|
Old December 20th, 2006, 04:43 PM   #15
message for 69fastback
message for 69fastback:
If you decide, let me know, and oh yeah, where you at :-)
Old December 20th, 2006, 04:44 PM   #16
They knew what I wanted, just didn't have any.
Called several salvage yards. Maybe I will just do the 302 since I already have it
Old December 20th, 2006, 04:44 PM   #17
82GT is an unknown quantity at this point
They had higher nickle content though 1974. The '69 & '70 engines only has better heads than the rest.
1982 GT (t-top)
351w(.060),10:3, ported & polished iron heads, 1.94/1.60 valves, BBK shorties & flowmasters, 274XE cam, stealth intake, mallory dizzy, stealth intake, 750dp, Edge 3700 stall converter, C-4, 4:10's
Best E.T 12.79@103.55mph
Old December 20th, 2006, 05:34 PM   #18
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
Re: message for 69fastback
I'm in oklahoma
./___ _ ____ ___ \.
\_ o _ _____ _ o _/
Old December 20th, 2006, 05:41 PM   #19
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
I meant to say nickel content. I was doing two things at once
I've always heard the 69 and 70 blocks and cranks were better. I did a quick search and the only thing I could get to come up were conversations on other forums like this one http://forums.tccoa.com/showthread.php?p=890520
I'll keep looking.
./___ _ ____ ___ \.
\_ o _ _____ _ o _/
Old December 20th, 2006, 05:43 PM   #20
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
Here is something else
http://www.enjoythedrive.com/content/?id=24092
./___ _ ____ ___ \.
\_ o _ _____ _ o _/
Threads Similar to: 302/347 or 351W
302 351w notsoslow50 5.0 Mustangs 6 July 26th, 2007 12:14 AM
11 Second 351w drthunder7 5.0 Mustangs 21 May 27th, 2007 11:06 AM
351w dragpipe General Tech 2 May 2nd, 2007 07:53 AM
351w FastBack71 94-95 6 February 4th, 2007 03:40 PM
351w ecu? 5-0stank 5.0 Mustangs 6 January 7th, 2007 01:13 AM
