running like doo doo
Old November 20th, 2008, 10:27 AM   #1
flattusmaximus78's Avatar
1993 5.ohhhh
12.97 @140mph
Well my top end kit went on my low compression 302. gt40p heads stock rockers cobra upper ported cobra lower and an fcam. IT hesitates hard core. No backfiring in the exhaust, and it occasionally stalls. But has no problems cranking up for a cold start. Note I have stock maf and injectors. Also when I give it gas it goes no where.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed
--Moates Quarter horse $225--
--Cobra intake $150--
--tremec 3550 bell and shifter $1100--
Old November 20th, 2008, 10:29 AM   #2
91 LX
13.7@101
u need to get a MAF calibrated for 24s. also check everything over 2, 3 or 4 times
Old November 20th, 2008, 10:31 AM   #3
1993 5.ohhhh
12.97 @140mph
Why would I get it calibrated for 24 pounders when I have the stock maf, and stock 19 pounders lol? Stock injectors maf and pump should be sufficient enough for my set up right now.
Old November 20th, 2008, 11:36 AM   #4
1992 Lx
11.39@119.24
dam dude should be running perfect, i pulled my usless chip out with my 7 cylinder tune and my car runs fine untuned at the moment, maybe your timing is completely fucked or firing order got switched slightly somehow
Old November 20th, 2008, 11:41 AM   #5
2002BLGT is on a distinguished road
Send a message via AIM to 2002BLGT Send a message via Yahoo to 2002BLGT
sounds like timing is off , or too much fuel or not enough fuel , get the fuel pressure checked and see what its at
Old November 20th, 2008, 12:02 PM   #6
dag545's Avatar
1995 Mustang GT
N/A
dag545 is on a distinguished road
It sounds like the timing is off. Mine did kind of the same thing when I put my cam in. When you installed the timing chain and gears did you do everything top dead center and were the gears straight up retard or advance? Also check the distributor to see if it is in the right timing location. I would get a timing gun and see where the timing is at.
Old November 20th, 2008, 12:37 PM   #7
The timing of the cam has nothing to do with how the ignition timing reads.
PeteAndersonRacing.com
Old November 20th, 2008, 01:08 PM   #8
1993 5.ohhhh
12.97 @140mph
Everything was top dead center with the timing chain and the number one one cylinder and what not. But I didn't degree the cam. I was told I could just throw that in, only one person said that could be it. I drove the car today it stalled whenever comming to a stop, and idled low as shit, didn't even cam. I got to pops out the exhaust between shifting gears.
A rocker arm bolt broke the other week. I dropped it off at a mechanics with the manifold off and distributer cap off as well. Also the timing went out of wack so he times it. Tomorrow I'm ganna take a timing gun to it, then mess with the idle screw I guess.
Threads Similar to: running like doo doo
Got Her Running, But wont stay running...help? Speedstang302 5.0 Mustangs 10 August 28th, 2011 05:58 PM
anyone know anyone running this? 07 STROKER 2005 - 2010 9 July 31st, 2008 04:40 PM
5.0 sd up and running :D 87mustang5.0 5.0 Mustangs 0 April 2nd, 2008 09:34 PM
running a little better e3sean 5.0 Mustangs 7 March 23rd, 2008 04:10 AM
I got my 73 up an running Katen Classic Mustangs 2 June 1st, 2007 04:56 PM
